View Poll Results: best plug for modded mid to high hp turbos
Bosch FR6 LDC
17
62.96%
denso PK20PR-P8
33.33%
NGK BKR9EIX
7.41%
denso iridium SK20PR-L11
0%
denso iridium IK20
3.70%
Multiple Choice Poll. Voters: 27. You may not vote on this poll
spark plugs
what kind of plugs are you using?
http://www.pulstar.com/images/iSeries.jpg
I have been using these with good success
I have had a few fail in my other cars but but am still ok with them. Every car I have put them in I could feel the difference. When i put them in my Honda element I could actualy hear the difference. They claim that there is a quicker burn which produces more pressure and hence more torque. I change them every driving season in the turbo just for the heck of it and to make sure the gap is set to .025".
Looks liek the Bosch Fr5 LDC has most votes - is this because it's the one step colder plug to the stock plugs? As for gaping, is the factory gap width ussually in spec or do most of you find yourselfs re-gapping the plugs? What do you think is the highest power range for the stock spec plugs?
fuel type, oxygenated, intake air temps, water/meth, and boost levels all play apart. Do you idle a lot, drive part throttle, and want the plugs to last for thousands of miles? run the stock plug. if your ecu is pulling timing step it back one colder and so on until you get what you are looking for. No two motors are the same and what works in one may not work for you. Test it for yourself. Gap.. open it up until you get a spark blow out then tighten the gap a few thousandths.
Did you take everything off the rear end or did you do it with the rearbumper/ic's/etc still on the car?
Altitude really should not be a factor in our turbocharged cars since an engine producing 0.8 bar at sea level or at 6000 ft "sees" the exact same amount of oxygen. In other words, 0.8 bar of pressure is the same amount of compressed air at sea level, 3000 ft, 6000 ft, etc....
Yes it makes sense in Theory,,,But in practicality,,,,it does make a difference....to what extend I do not know....Air has less oxygen ,less condensed, at higher altitudes.So, the range that the mechanica/electrical sensors can compensate for that are only in a narrow window....Thats why a good tuner will ask what elevation you live in ,if it is not a common one.......Just letting you know my thoughts.......
I pulled the rear bumper because I didn't know at the time how to do it without pulling it. It wasn't too difficult IMHO.
