Dyno Turbo
Old Mar 22, 2005 | 02:48 PM
Tpup's Avatar
Tpup is a name known to allTpup is a name known to allTpup is a name known to allTpup is a name known to allTpup is a name known to allTpup is a name known to all
Dyno Turbo
Howdy,
I am trying to do a dyno run on my turbo. The place that does it cannot find a plug wire to connect too. I went by the dealer and was told that there are no plug wires on a turbo... Where are you guys connecting to get the equivalent to a plug wire??
Thank you.
Roy
Old Mar 22, 2005 | 05:39 PM
PorschePhd's Avatar
You need to pull the signal wire to the coil pac. You can get to number 4 coil on the front/right side of the motor. Follow it up from the coil in to the harness. Peel back the plastic cover and tag the green wire. That will give you a tach signal.
Old Mar 22, 2005 | 06:23 PM
cjv's Avatar
cjv
Moderator
Re: Dyno Turbo
Originally posted by Tpup
Howdy,
Thank you.
Roy
Roy,
With what you have told me about whoever is doing your dyno, I would not let them do any more. They are lible to do more damage than you can imagine.
Free advise is worth exactly what it costs you.
Old Mar 23, 2005 | 07:34 AM
Tpup's Avatar
Thanks for the feedback. CJV, I understand you point. I'm looking for another source since these guys seem to lack P car experiance...
Thanks again.
Roy
BlackMarketRacing
Dec 3, 2015 10:46 AM
Oct 6, 2015 05:20 AM
albert@velosdesignwerks
Ferrari
Aug 22, 2015 09:31 AM
