Questions about smoothness of a stock 996tt (MT)
For those of us with a stock engine and a manual transmission:
Do you experience some engine 'bog' if lets say you're driving in 2nd or 3rd below 2000rpm and you suddenly try accelerating? What I get is a unrefined feeling from the engine until the turbos spool up (then it's smooth, and a little scary!). I don't really know how to explain it but I'm sure if you have the same you'd know.
And in general it might be just me, but I feel all the mechanics work much much smoother if you keep the car in the boost range (above 2700rpm), engine and gear shifts. Below that the engine is not very smooth and the gear shifts are also less smooth than higher-rpm shifts.
It would be interesting to hear from other stock 996tt owners...
the Op's post is timely for me as I've only recently noticed a barely perceptible yet annoying hesitation, but mine seems to occur only when attempting to maintain a steady speed in higher gears btw say 2750/3k rpm. My intial thought after a lot of reading in here was to have the maf replaced. Only14 days left under cpo warranty! Argh.
Btw.. New tires on 'er so anytime ya wanna hit Malibu cyn lemme know!
I've search through the forums and have talked to enough experienced techs to come to the conclusion that this hesitation could just be "normal" on the 996TTs. Some are more noticeable than others. Mine is barely noticed when I'm cruising along, very lightly on the throttle, and usually in 3rd or 4th gear -- right around 3K rpms. For me, it never occurs when I'm on the throttle and the car is pulling hard (if so, plugs may be the first thing I'd look at). In fact, it's so subtle that my passenger never feels it. But I also acknowledge that I'm hyper-sensitive to this kind of thing -- for example, "where's that $#@% ticking/creaking sound coming from? Oh it's a pen rattling in the glove box.....".
From what I can tell, theories point to the e-gas, variable valves, turbos, or even some play in the drive shaft. I haven't come to the conclusion that it's worth swapping out parts or blindly replacing things.
Other thoughts or experiences?
For what it’s worth, mine does the same thing. Very slight hesitation when I'm trying to maintain a steady speed while cruising. Seems to happen mostly between 1800-3200rpm.
Put a new MAF in and have had my data logs looked at by Kevin/UMW and nothing seems out of place so I'm not going to worry about it unless it gets worse or starts throwing codes.
One thing I've noticed is that it doesn't seem to do it when I've got cruise control set. I haven't had an opportunity to try this enough (going up and down hills etc.) to draw any conclusions from it but it makes me wonder....
Do you experience some engine 'bog' if lets say you're driving in 2nd or 3rd below 2000rpm and you suddenly try accelerating? What I get is a unrefined feeling from the engine until the turbos spool up (then it's smooth, and a little scary!). I don't really know how to explain it but I'm sure if you have the same you'd know..
Now the 'stumble' that others are describing sounds either like a miss due to plugs or the variocam changeover point....
I assume it's pretty normal, had two turbos both seemed the same, around 2k rpm you are getting at the point when the boost starts to take affect causing a surgey type feel if you attempt to maintain that range.
Theses cars want to go fast, it's what they are built to do, so creeping around in traffic at low rpm makes the car difficult to drive smoothly.
It seems true with lots if high horsepower cars, great on the track not so much in traffic. Reverse for low horsepower cars, great in traffic, crap on the track.
I'm due for a canyon drive!
By all means, let's hit Malibu cyn soon. They've repaved it from the 101 all the way to pch. Fresh blacktop!
I'vhesitation could just be "normal" on the 996TTs. Some are more noticeable than others. Mine is barely noticed when I'm cruising along, very lightly on the throttle, and usually in 3rd or 4th gear -- right around 3K rpms. For me, it never occurs when I'm on the throttle and the car is pulling hard (if so, plugs may be the first thing I'd look at). In fact, it's so subtle that my passenger never feels it. But I also acknowledge that I'm hyper-sensitive to this kind of thing -- for example, "where's that $#@% ticking/creaking sound coming from? Oh it's a pen rattling in the glove box.....".
I experience a little (very little) below 2K when cold, but from 2K on the engine is as smooth as could be all the way to the rev limiter. After the car is completely warm the hesitation is almost imperceptible (the passenger wouldn't know it's there).
I'd definitely like to hear if this changes things. Best wishes.
