Carbon Fiber Dual Intake System!
I may be interested in this also...why are you getting rid of it? How much are you looking to get?
note how my comment asking for dynos from customers was not answered.
#TeamAIM
#TeamAIM
what's the sound difference like? I know the EVOMS intake makes the turbo spool notably louder. Is this the same effect? I would assume so as more airflow and less restriction means more turbo spool noise.
Edit: from my experience with intakes on my BMM 335xi with it's N54 engine, an intake is not really a hp gaining mod as more of a sound gaining mod, when I had the my stock intake on I could barely hear the turbos spool, in fact it was almost inaudible like that of the Audi a4's, but once I put in the DCI intake, which wasn't even a true cold air, man oh man did those things make lots of noise. I loved it, and would buy it again in a heartbeat, but that intake was also only $125 or so lol. Main reason why I don't want to get the EVOMS is because I can't really justify spending almost a grand for basically just sound.
If you read the original post that was linked on the first page somewhere, you cant really DYNO the value you of this intake. The point is for the car when moving to bring in more airflow into the airbox. If the car is sitting on a dyno, all you are measuring is what the stock filter, K&N, or BMC is sucking in without any airflow being forced from movement of the car.
Those three represent some critical track points at which aero data can be measured and compiled, if we can assume a correlation with increase in speed proportional to some fractional gain by your airbox then we can run with and without scenarios to attempt to quatify the gain.
selling 100 units does not measure gains...feedback, albeit good does not measure gains. If you were able to say that at this track at this point on the track then same car with the same driver on back to back sessions showed a gain of 2mph terminal speed that would be a good start...
not trying to be a pain in the butt, just sharing some thoughts that's all
...personally I really like the part, especially in carbon or kevlar (but that kevalr is pricey!)
in theory and design wise your part should work to produce some sort of gains perhaps. what I (and others apparently would like to know) is by how much. For that you need imprical data...you mention track guys....have you asked for Data aquisition speed at points such as (1) entry into a specific turn (2) terminal speed at the end of a straight into the brake zone (3) exit speed coming off a turn into a major straight.
