Spool up on Alpha 3071's
Old Mar 10, 2011 | 08:24 PM
GTstreet996's Avatar
GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !
When should the Alpha 3071's with all the supporting mods be spooling? Why I ask is that mine are starting to spool at 4100.
Also do you think having 47.5 m headers are cause the turbo lag?
Thanks,
Old Mar 10, 2011 | 08:41 PM
pinoy911tt's Avatar
pinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to beholdpinoy911tt is a splendid one to behold
i see mine full boost at about 3200-3600. i have stock headers though and marki's 2.5 inch pipings to the turbo.
Old Mar 10, 2011 | 08:48 PM
That is a huge difference!! Mine full boosts at over 4400
Old Mar 10, 2011 | 09:01 PM
pinoy911tt's Avatar
i also still have stock intercooler hoses and y pipe so i'm not sure if that's where the difference is
Old Mar 10, 2011 | 09:24 PM
If you swap out those restricted parts shouldn't you have an even quicker spool?
Old Mar 10, 2011 | 10:54 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
It should help a lot if you run bigger ducts to the inlets of the turbo. I have some 2.5" hose if you are interested PM me. My alpha 3076s spool the same as my 24/18Gs did!
Old Mar 11, 2011 | 12:42 AM
Thanks mang but I have all the supporting mods. I'm putting smaller headers on this weekend 44.5 and see what happens to the boost response
Old Mar 11, 2011 | 07:50 AM
4400 seems late. have you tested for leaks?
#TeamAIM
Old Mar 11, 2011 | 07:58 AM
I did a smoke test and tightened a few areas but nothing dramatic.
Old Mar 11, 2011 | 08:00 AM
TiALSport's Avatar
TiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond reputeTiALSport has a reputation beyond repute
this
something is holding you back - 3076's are at full boost around 4K
Old Mar 11, 2011 | 08:28 AM
Agreed. The boost response was the main reason why I went with Alpha's.
Can having bigger diameter 47.5 headers cause this much of a difference?
Old Mar 11, 2011 | 08:32 AM
eh maybe. bigger diameter primaries - slower velocity of air traveling through, given that the volume of air is constant. blow in a straw and then in a bigger straw with the same intensity...
#TeamAIM
Old Mar 11, 2011 | 09:04 AM
Neil Switzer's Avatar
Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !Neil Switzer Is a GOD !
R911 997TT hits 800awtq (ft/lbs) at 4400rpm, ramping in the boost.Turbos we run are custom 30's.
Old Mar 12, 2011 | 08:53 AM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
Neil at what boost LOL
Old Mar 12, 2011 | 01:42 PM
dgreen78's Avatar
Another thing to check for is your wastegate preload on each turbo. I found that Tial does not set these from the factory. On the dyno we found one set at a crack point of 12 psi and the other at 15 psi. My turbos spooled up a few hundred RPMs quicker when we found this out.
