Problem Starting the 996 Turbo
i would take it to someone that knows Porsche audio. i have NEVER had a p that had an after market stereo that didn't kill the battery. once the car starts it charges the battery so it will appear that the battery is good... i don't bother changing the stereo now.. and i alway look my car in the garage too. do you have a aftermarket head unit, or an amp too? i know that i am not the only one that has this issue. btw: congrats on a great car; i have the same one> if i were a betting man. i'd put my money on the radio.. i had the same problem.. hence, the gps never turns off..... the electric's in these cars are very sensitive,
I only have 2 keys and both have the remote. I did tried both keys and even used the key to manually open the door thinking maybe is the alarm stopping the car from starting.
See the pic for the loose part that I tighten by the clutch. It look like a switch and not relay. But it is not the red/black lever switch that is sensing the clutch position.
Not sure if this gray part has anything to do with the clutch and if itis loose, could it cause it not start?
The clutch switch could definitely cause everything to go quiet when you try to start. If in doubt - hard-wire it (but don't forget to put it back after).
tropicatango
Jun 8, 2025 01:00 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
