proper wheel diameter for ps2
Old Mar 22, 2011 | 07:24 PM
snopdog911's Avatar
snopdog911 is infamous around these parts
is 235 35 19 and 315 25 19 okay for awd?
ps2 front is 25.5 and rear 25.2
revs per mile 817 front and 824 rear. so .991
i thought .2 was within spec
is this going to be an issue
Old Mar 22, 2011 | 07:47 PM
eglivincent's Avatar
eglivincent is infamous around these parts
those are the correct 19" sizes for our turbos.
Old Mar 23, 2011 | 09:17 AM
Joe Weinstein's Avatar
Yep. no problem with those diameters.
Old Mar 23, 2011 | 09:34 AM
bk doc's Avatar
bk doc is infamous around these parts
That's what I've been running for a few years now with no problems.
Old Mar 23, 2011 | 11:49 PM
coastalb55's Avatar
coastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant futurecoastalb55 has a brilliant future
That's what I was running until recently (still using same sizes but in Nitto Invos)
Old Mar 24, 2011 | 02:56 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
I have the same set up for 5 years no issues.
Old Mar 24, 2011 | 09:50 AM
TekNiC3's Avatar
TekNiC3 is infamous around these partsTekNiC3 is infamous around these parts
225/35/19 will be a closer match to the 315/25/19.
Old Mar 24, 2011 | 04:57 PM
snopdog911's Avatar
so if the ratio is off, will it be noticeable immediately...
or is the effect accumulative? ie, may take years to notice?
Old Mar 24, 2011 | 05:04 PM
Duane996tt's Avatar
The tire and wheel combination you mention is within spec. If the ratio is outside of spec you might notice some slight handling differences. However the big surprise comes later when your front differential goes out.
Zero911
Aug 24, 2015 06:51 PM
metzkaro
Aug 24, 2015 02:59 PM
