Volk Racing TE37 after install pics.
Old Apr 7, 2011 | 03:41 PM
Spam16v's Avatar
Spam16v is infamous around these parts
Read the tittle and cringed, I stand corrected, they look really nice. Get some good day shots as the photo looks deceptive as far as stance/offset.
Old Apr 7, 2011 | 07:03 PM
pateshu's Avatar
pateshu is infamous around these parts
Wow, looks fantastic! I agree on the spacers in the rear though.
Old Jul 11, 2011 | 09:51 AM
Talisman013's Avatar
Talisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond repute
I just found this out recently, but the little yellow circle on the tire is supposed to line up with your valve stem. The tire was counter balanced intentionally to lower the weight need to balance the wheel. Just wanted to share, im sure a lot of peeps already knew.
Old Jul 11, 2011 | 03:05 PM
RxPorsche's Avatar
RxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud of
Thumbs up
I did not know that thanks for sharing.
Old Jul 11, 2011 | 08:38 PM
Myclue's Avatar
Myclue is a jewel in the roughMyclue is a jewel in the roughMyclue is a jewel in the roughMyclue is a jewel in the rough
looking great!
Old Jul 11, 2011 | 08:45 PM
SupremePower's Avatar
SupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud ofSupremePower has much to be proud of
The yellow dot is a great starting point to mounting the tires however shops like ours who use a Hunter Road Force machine will not always have the dot by the valve stem since the machine tells us where to rotate the tire on the wheel after it has been mounted
If a shop doesnt have this type of equipment then the best way to mount the tire is with the dot by the valvestem
What about the red dot? -- The red dot is placed at the valvestem and the yellow is overlooked if a red dot is present
Old Jul 11, 2011 | 10:49 PM
Sterlingc1975's Avatar
Sterlingc1975 is infamous around these partsSterlingc1975 is infamous around these parts
Looks good
Old Jul 12, 2011 | 09:06 AM
RxPorsche's Avatar
Thumbs up
I really believe this because I have not see a rim with so little weight added for balance. Thanks again for a great work .
Old Jul 12, 2011 | 09:09 AM
RxPorsche's Avatar
Originally Posted by Myclue
looking great!
Thanks to all, will do some day pics soon if work give me a break .
Old Jul 12, 2011 | 03:12 PM
besiktas's Avatar
besiktas is infamous around these partsbesiktas is infamous around these parts
what is the weight of the front wheels?
Old Jul 12, 2011 | 06:05 PM
besiktas: 18 to 19 lbs
Old Jul 12, 2011 | 08:23 PM
Thats very cool. Just so Im clear on this, you mount the tire completely, pressurize, spin it up. Then the machine tells you to de-pressurize and rotate tire?
Do you have to spin it up with just the wheel for reference? It seems you would, otherwise how would it know its the tire and not the wheel?
Also, didnt mean to hijack, I am very interested in this answer.
Old Jul 12, 2011 | 08:26 PM
The machine has a large roller which comes down in contact with the wheel and tire and spins it and simulates the wheel as if its on the ground. The machine will then calculate the amount of roadforce the wheel and tire are creating and make a suggestion on how it can reduce the roadforce. When you reduce the roadforce you also decrease the amount of weights used as well.
So yes you would deflate the wheel wheel and tire and take it back to the mounting machine and spin the tire on the rim to the spot the machine told you to move it to.
awdbiturbo1
Feb 18, 2016 10:24 AM
COBB Tuning
Nov 9, 2015 08:02 PM
Aug 21, 2015 09:56 AM
