Highest HP Modified K24 Based Engine
Old Apr 18, 2011 | 05:20 PM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
I'm def going in that direction w/my car....gtx20G but tuned on E85.
Old Apr 18, 2011 | 05:21 PM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Originally Posted by OS Inspector
Sell? **** i haven't even got to enjoy mine yet.
OS you still haven't fix your broken engine ?? if so i'm very sorry it has taken a long time and i imagine a lot of money .I hope you solve that soon to start enjoying your car.Good luck my friend.
Old Apr 18, 2011 | 06:24 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
so your gonna put a Garret GTX wheel ina 20g? seems like an odd combo if it would work
i assume you meant a k24/20gxt setup?
Old Apr 18, 2011 | 06:36 PM
k-ore's Avatar
Your assumption was correct; my combo of alpha characters was off.
Old Apr 18, 2011 | 06:44 PM
johnspeed's Avatar
So Guys,,Let me get this right,,,Are you saying that right now,,there are 18g and 20g GTX billet wheels that will fit in the K24s????.....I was going to the Dyno Thursday to have my map revised for my new exhaust system.....So,It would really help to get the facts on this......Thank You
Old Apr 18, 2011 | 06:47 PM
no there are Billet versions of the 18g and 20g wheels out there designated XT so 18gXT and 20gXT
these cost the same as the regular 18g/20g conversions as i was told
GTX = Garret wheels and not related
Old Apr 18, 2011 | 06:59 PM
MexIcant's Avatar
MexIcant has a reputation beyond reputeMexIcant has a reputation beyond reputeMexIcant has a reputation beyond reputeMexIcant has a reputation beyond reputeMexIcant has a reputation beyond reputeMexIcant has a reputation beyond reputeMexIcant has a reputation beyond reputeMexIcant has a reputation beyond reputeMexIcant has a reputation beyond reputeMexIcant has a reputation beyond reputeMexIcant has a reputation beyond repute
Originally Posted by bmoores
I'm going to strap my car to the dyno one of these days but at 1.6bar on the 20g's my guess is that the car makes damn close to that number. I need to adjust my wastegates but i'm confident this car will go 5.5 or better 60-130 with 1 shift. If we are going to (bench race for the sake of discussion ) compare those numbers with cars that have made similar power on the 60-130 charts the the car below me made 755 and the car above me made 724. I don't think my car is making 755 or anywhere near it but it should be in the 680 range.
I think Chris Green made 717whp on 24/18g's and E85. Thats the highest number I've ever heard on a K24 based turbo. There is the white 24/20g car up in MN that used to belong to Bobby. That was running 1.8 bar on C23. That car trapped 143mph if my memory serves me correctly and ran a 9.99 from what Todd Knighton told me. I would guess that car was making roughly 750whp.
Old Apr 18, 2011 | 07:22 PM
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
Originally Posted by MexIcant
Why the confused smiley??
Old Apr 18, 2011 | 07:51 PM
johnspeed's Avatar
.....Wow....I have to look into this....My fellow PCA member got his K24/18g done a month ago at Blouch and they were the standard Mits. wheels...Thanks.....
Old Apr 18, 2011 | 07:54 PM
yea i believe you can still order both types old wheel or new wheel
Old Apr 18, 2011 | 08:13 PM
k-ore's Avatar
Link to said info?
Old Apr 18, 2011 | 08:50 PM
Link to said info?
http://forums.nasioc.com/forums/show....php?t=1947550
post #10 from blouch shows the # per min on new wheels
old k24/18g rates here
http://forums.pelicanparts.com/911-9...low-rates.html
and the price quote i was told under 1500$ from someone who is getting it done by EPL for a stock set of k24's upgraded to 18gXT hereis the link to the member that is getting the 18gXT https://www.6speedonline.com/forums/...ml#post3172338
best i can do for ya as blouch doesn't list it on their website.
Old Apr 18, 2011 | 10:16 PM
k-ore's Avatar
Thank you kindly for the info, i'll contact blouch to see the turn around time on my K24s.
OS...might I ask how much boost can I run on the new billet 20g's before I need to upgrade fuel, ic's and all that good stuff?
Old Apr 19, 2011 | 06:56 AM
bmoores's Avatar
Anything over 1.2 without proper fueling, IC's and piping on 20's will be dangerous. In fact I would say you are wasting money getting the 20's unless you intend to do the appropriate supporting mods. The 20's really shine on higher boost and without those supporting mods it would be dangerous (fueling) and inefficient (breathing). If you want to keep it simple do the 18's you can get away with fewer supporting mods.
Old Apr 19, 2011 | 09:06 AM
if you have stock injectors and stock FPR and stock Fuel Pump id say you wouldn't get much past .6bar with that much bigger turbo then stock.
20g's are big boy turbos
to make full use you need to remove the restrictions. if you dont they will be more laggy then an 18g and not make as much power as your looking for.
if your not prepared to get IC's Ford MAF, 3" intake piping second fuel pump big injectors along with the 20g's just get the 18gXT you'll be happier and if you want to go bigger later the cost to switch from 18gxt to 20g isn't much.
also a 20g turbo will destroy most clutches you'll need an upgraded clamp load clutch with fiber tough or ceramics to hold on a single disc, or get into a twin disc clutch.
