Esprit dyno results
Re: Re: Re: Esprit dyno results
Originally posted by 1999Porsche911
Stock GT3 has approximately 325 RWHP.
With my Europipe/filter I expect 360+ rwhp when I dyno it again 4/16....
Re: Re: Re: Re: Esprit dyno results
Originally posted by rockitman
Let's see, I dynoed my GT3 stock right after breakin and it was 348 rwhp on a mustang chassis dyno. Others I have seen have been 350, 352 ect. You get the idea....
A bench tested engine showing 380 HP that is put in a Porsche will have more than an 8% drivetrain loss. I guess I should have my car dynoed on a Mustang so I can show that I have more than 460 RWHP in my little old 996.
Re: Re: Re: Re: Re: Esprit dyno results
The Mustang Dyno historically shows 5 - 7 % higher than other dynos.
A Mustang Dyno requires that you enter a weight for the vehicle and then provides a resistance throughout the entire run, simulating wind resistance. For this reason, it is an excellent tuning device but its no good to put down big numbers. Once a car begins moving, there is less resistance at the wheels when you overcome the polar moment of inertia, but the Mustang Dyno keeps applying this force acting against you. If you were on a Dynojet you would only have to overcome the polar moment of inertia and then you'd have nothing but BIG numbers. The Dynojet will generally put down another 10-15% more whp than a Mustang Dyno.
Re: Re: Re: Re: Re: Re: Esprit dyno results
Where is the proof for that statment ???
Like I said before, f you want to use a dyno for tuning, it may work fine for you. But unless you are racing someone else on a dyno, they are useless in determining actual power to the wheels. They are an mathematical estimate only.
well I disagree with your rwhp assesment of the GT3. Perhaps your figures are closer for the 1999 Mark 1 GT3 variant...anyways, not interested in a pissing match either...What it will do for me is tell me the power increase my car has with the addition of a new exhaust system. I already have a base stock dyno from the same machine at the same place....
That's the way to do it. Then compare what happens to the numbers after the mods. Take a close look at the low end torque number after you change exhausts. If you are going with a more free flowing exhaust, you should see the bottom end torque decrease. Also get a printout of all the parameters used when dynoed. I have seen many shops adjust the air temp and pressure inputs just to show bigger numbers.
My friend is a mechanic at Ferrari (Maranello up here). He has told me the 360's normally put down between 300-320whp depending on the dyno. So maybe its not drivetrain loss, but Ferrari lying about the numbers. Wouldn't be the first time a manufacturer has pumped up the numbers of its cars to sell them. Then again, maybe they just have an extremely parasitic transmission/driveline, who knows.
Originally posted by ben, lj
if yawl really believe a 425 hp CS dynos out at 329 RWHP...
Originally posted by allanlambo
Would you like to put your money where your mouth is? Several people on Fcrap dynoed their CS's, all in that same rwhp catagory.
