Pcm2
Old Apr 27, 2011 | 06:54 PM
legit526's Avatar
legit526 is infamous around these parts
Pcm2
Guys,
my PCM2 starts clicking upon startup when a cd has been inserted prior to startup and fails to load the navigation.....keeps saying loading........anyone have any suggestions besides completely replacement. I prefer the stock look so i know my options are limited.
Old Apr 27, 2011 | 08:58 PM
jorligan's Avatar
jorligan has much to be proud ofjorligan has much to be proud ofjorligan has much to be proud ofjorligan has much to be proud ofjorligan has much to be proud ofjorligan has much to be proud ofjorligan has much to be proud ofjorligan has much to be proud ofjorligan has much to be proud of
Don't know but if necessary, I have one that works perfectly which I am taking out of my car this weekend
Old Apr 27, 2011 | 11:52 PM
ard's Avatar
ard
Take it apart and clean the optics.
Old Apr 27, 2011 | 11:55 PM
legit526's Avatar
the clicking sound that comes from the cd player would equate to a dirty optic lense?
regular cd's play with absolutely no issues.
Old Apr 28, 2011 | 01:42 AM
dragonman4's Avatar
dragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond reputedragonman4 has a reputation beyond repute
Is the cd jammed in there? I had that issue before in one of my previous cars where the motor that pulls the cd into the device jammed the cd in a certain way that the cd insert sensor kept tripping and reactiving the motor that pulls the cd into the tray.
Old Apr 28, 2011 | 09:45 AM
legit526's Avatar
cd isn't jammed at all......it comes out and goes in just fine......sometimes the sensor will a game back and forth but if you leave a cd in there and start up the car it will start clicking for a while before it actually starts playing or state there is no cd at which time i have to remove and reinstall the cd.
Old Apr 28, 2011 | 11:33 AM
ard's Avatar
ard
Well, I am not going to give you a 'rifle shot diagnosis' from here...but in general, data on a DVD is much higher density than a CD. AS the data is read off the disc, if there are errors the system tries to 're-read'... as the head begins from the start track it will try and pick up the data- if it continually gets errors it will reset and retrack- this can make a clicking sound.
I've had this issue on other nav drives- CDs no problem, data DVDs a problem. Clean optics and it worked.
But, as I said, it can be many things and NOBODY will be able to diagnose it outside of a few engineers that designed the PCM. (And even then they too will need to open it or attach it to a testbed.) So try the easy stuff, then once you reach the tipping point replace it.
Old Apr 28, 2011 | 11:53 AM
legit526's Avatar
ok lets try that.........how do i go about cleaning optics? sorry i dont want to mess anything further up.
Old Apr 28, 2011 | 12:54 PM
Tj Hunter's Avatar
Tj Hunter is infamous around these parts
Take unit out of car, take the metal bracketing off the actual unit to expose the inside of the CD unit. Take more apart to get to the laser mechanism, use a q-tip with 90% Isopropyl alcohol, and reassemble.
Otherwise dealer or indy.
Mark esc cos
Jul 16, 2015 03:33 PM
b4stiTTS
May 26, 2013 06:14 PM
b4stiTTS
May 18, 2013 03:53 AM
b4stiTTS
May 18, 2013 03:52 AM
serge1ny
Sep 12, 2012 02:09 PM
