P491 & 492 Can I drive it ?
Old May 5, 2011 | 06:29 AM
03 996tt's Avatar
03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future
Got Cel for p491 and 492. says drive to shop. dont have time for a few days. can I drive it in the meanwhile?
Old May 5, 2011 | 07:07 AM
jpflip's Avatar
Yes you can. Those codes are related to the secondary air injection system and it can be due to a leak in the vacuum lines on top of the engine....Function: inject fresh air in the catalytic converter for emission control on cold start. Did you hear the air pump starting on cold start. This pump is located in the engine compartment , right front corner....
Old May 5, 2011 | 07:56 AM
VAGscum's Avatar
Hey, did you replace the diverter valves yet? If they haven't been replaced do those and see if the code goes away. Those have been known to cause those codes.
Old May 5, 2011 | 08:39 AM
landjet's Avatar
And if you have aftermarket DV's, check to make sure the tops have not come loose. One of my tops was loose and I got those CEL's. Tightened it up and the CEL went away.
Old May 5, 2011 | 09:02 AM
03 996tt's Avatar
Jpflip. Thanks for always responding quickly to my posts. It is really appreciated!!
I'm not sure what the pump sounds like as my car is very loud at start up (Tubi Exhaust)
Vagscum I checked them with my mighty vac after we met some mos ago. at that time, they held vacuum for 10 min each, but I guess its time to retest
I guess its time to upgrade my dv as they are stock and should eliminate that concern. I used my buddies Durametric to clear the codes and drove about 20 miles and so far nothing yet.
Thanks for all the advise
Old May 5, 2011 | 11:29 AM
landjet's Avatar
Sometimes it takes 5 or 6 engine on/off cycles for a CEL to return after clearing codes if the problem is still there.
Old May 5, 2011 | 01:28 PM
jpflip's Avatar
Welcome. It is always a pleasure to help you if I can! Of course I agree with Landjet and VAGscum it can also be the diverter valves....
GetALife75
New Member Introductions
Sep 3, 2015 12:22 PM
Gus_Smedstad
Aug 29, 2015 04:43 PM
LiquidElephant
Aug 27, 2015 06:17 PM
AdPock
Ferrari
Aug 27, 2015 03:38 PM
DerekShiekhi
Other British Cars
Aug 19, 2015 05:25 PM
