installed speed gallery wastegate actuators 1bar spring
Old Apr 5, 2005 | 09:07 PM
calbobba996TT's Avatar
calbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the roughcalbobba996TT is a jewel in the rough
take a look, the car feels stronger especially
in the higher rpms and now i see 1.1 some spikes to
1.2. befor it wouldn"t make more than 1.0
boris
boris
Old Apr 5, 2005 | 09:57 PM
KPV's Avatar
KPV
Boris,
Can you please explain in more detail what this modification entails?
Thanks,
Ken
Old Apr 5, 2005 | 10:06 PM
They were pre set when i got them, from what i understand
the spring inside the actuator is replased with a 1 bar instead
of .7bar. it keep the wastegate from flapping under boost.
I hope some one from speed gallery will help me out here
and explain a little beter.
boris
Old Apr 6, 2005 | 12:05 AM
Craig's Avatar
Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !Craig Is a GOD !
I think you are correct Boris that upgraded springs are employed to achieve and sustain greater boost. My new set up will be using the same wastegate springs.
Craig
Old Apr 6, 2005 | 01:09 AM
Turbo Fanatic's Avatar
Boris pleae explian rear wheel drive cars! Did you remove front driveshaft? How does it affect handling? How does it affect skid control?
Sounds like a cheap GT2 conversion! Not exactly, but....
Old Apr 6, 2005 | 01:13 AM
the car was completly converted to gt2 spec inc
all suspention and brake omponents. it retained traction control
boris
Old Apr 6, 2005 | 01:17 AM
sharkster's Avatar
Boris I drove mine around for a while in 2WD but dayum it was too crazy and I went back to AWD. Too much power for RWD.
Old Apr 6, 2005 | 01:30 AM
just went to sears point this sunday and had a blast
with it .
boris
Oct 6, 2015 05:20 AM
MadWhip
Sep 3, 2015 02:04 PM
riozilla
Aug 21, 2015 11:34 PM
Regent
Aug 21, 2015 11:14 AM
