Help choose a lift for my garage?
Old May 19, 2011 | 12:38 PM
  #31
Tj Hunter's Avatar
Tj Hunter is infamous around these parts
Originally Posted by xc17pilot
I installed the Greg Smith 8000 lb 4-post lift 2 years ago. It works great, has been maintenance free. I also purchased the scissor lift that slides between the two rails which is perfect for wheel swaps, brake jobs, and suspension work.
One MUST is to anchor it to the floor. They say it is optional, but BS to that. It will "walk" if not secured to the garage floor.
Good luck.
How do you like the scissor lift? I am looking for something that I can use to do almost all maintenance, 2 post lift style, but I want portability, I am going to be moving around for the next 3-4 years, and I want something that I can take with me.
Old May 19, 2011 | 01:00 PM
  #32
Mike in MD's Avatar
Mike in MD is infamous around these parts
I have a Bendpac 2 post Asym. Going on 5 years old, lots of use, and trouble free. Installed it myself in an afternoon.
I went with the taller "clear floor" option as I designed the garage around the lift, so ceiling heigh was not an issue. I didn't order them but at the time Bendpak offered optional low profile arms for lowered cars. When I need to get my son's lowered M3 on the lift I use a set of foot-pump dollies to raise the car an inch or so, and then just wheel the car into place and swing the arms under the car.
Be ready to have a lot of new friends on the weekends...
Old May 19, 2011 | 02:45 PM
  #33
xc17pilot's Avatar
xc17pilot is infamous around these parts
Sorry for any confusion when I said I have a scissor lift - it is a scissor style jack that goes with the 4-post lift. This device sits between the two metal supports that you drive the car on to. The scissor jack then can slide under the car to lift either axle at the normal jack points on the car.
Old May 19, 2011 | 06:18 PM
  #34
jayster's Avatar
jayster is infamous around these parts
Get the Rotary Brand SPOA7000 lifts with the "Porsche/BMW" low profile arms. It is the only way to go.
If the home is "modern construction", a foundation slab is probably 3000 psi concrete,
it needs to be 6" deep, and should be tested if not certified by your builder.
However, with these lifts ( I have two, for close to 10 years now, zero defects. ) I have serviced GT3's and Carrera GT's on them, not to mention all sorts of slammed 996's, and hot rod Audi's. Have owned many different lifts in the last 30 years, I wouldnt buy any thing else.
Jay Putnam.
Old May 19, 2011 | 11:27 PM
  #35
Tj Hunter's Avatar
OH even better...wow there are so many options. I think I like the 4 post idea a lot more and use the scissor that you have.
Old May 20, 2011 | 09:36 AM
  #36
Tim941NYC's Avatar
Originally Posted by jjbravo
Love my Rotary 2 post asymmetric.
Get the 3 stage arms.
plus 1. You can get the low profile lift arms too. Although the lift I put in in my warehouse was bought through my local snap on guy. Not a rotary but the same exact thing only in black and no low profile arms, nothing hockey pucks could not fix!
Old May 20, 2011 | 11:45 AM
  #37
ogomez79's Avatar
ogomez79 is infamous around these parts
2 post makes life so much easier. The only downside is it requires a little thought getting the car centered between the posts and front to back. I purchased a set of the wheel dollies like mentioned above. It makes life so easy, just slide the car around to where it needs to be and lift.
Old May 20, 2011 | 12:57 PM
  #38
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
I have a 4 post, Direct lift, easy to drive on with lowered car,..
I was told 6" minimum for the concrete, but if they tell you 4"...? Did you watch them poor it? Did they measure every few feet to assure 4"...? I would hate for something bad to happen to the car or you if 4" isn't enough or they poored it too thin...My 4 post is great, tires come of with a scissor jack or any other jack that will fit. Easy, just drive on and push the button. Easy and cheaper install as well.
Old May 20, 2011 | 04:18 PM
  #39
shtfrbrains's Avatar
shtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud of
Jay Putnam.
Are the low profile arms low enough that you can drive up and lift a GT2 without driving onto blocks first? That would be the best.
Old May 20, 2011 | 05:17 PM
  #40
jayster's Avatar
Absolutely....
Old May 20, 2011 | 05:19 PM
  #41
jayster's Avatar
BTW 4" is not sufficient for lifts or foundations.....
Old May 21, 2011 | 02:28 PM
  #42
sunir's Avatar
GT2 is notoriously low from the factory I agree...last time I took my car in they put in a lift using the hockey pucks I supplied myself...they are always ready to go in the car just in case!
Old May 25, 2011 | 11:54 AM
  #43
cyanidecotdpnut's Avatar
cyanidecotdpnut is infamous around these parts
4" of concrete are enough as long as it is the correct PSI, at least for some smaller lifts like the MaxJax (each anchor bolt can withstand 10,000 lbs). 6" works as well, and if you have the $$ by all means go for it. The downside of a 4 post w/ the scissor jack is that it blocks alot of access to the midsection of the car.
Old May 25, 2011 | 06:15 PM
  #44
jayster's Avatar
Overkill wont get you hurt, 4" of concrete can, even at 3000 psi. Most of the cars are not balanced like 944's. I have to strap CGT's to the front arms to keep them from tipping off, think of the mechanical moment involved in this arrangement.
6" is a minimum @ 3000 psi.
Old May 25, 2011 | 06:48 PM
  #45
What about some kind of heavy steel base plate or something? Is that a safe alternative? My garage floor is 4 inch, 3000 psi. but I agree, more is better.
Also, the tipping issue you speak of with the CGT, is that on an asymetrical or symetrical lift? Which do you recommend for my GT2?
