How important is an exaust, really?
Old Jun 13, 2011 | 01:38 PM
  #31
1BADBURB's Avatar
1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !1BADBURB Is a GOD !
so is a tune required if you just bolt on an exhaust? will it set off an CEL's?
adding an intake, would that require a tune too???
Old Jun 13, 2011 | 03:25 PM
  #32
daytrip00's Avatar
daytrip00 is infamous around these parts
It's my understanding that some exhausts (mostly the 100 cell ones) can set off O2 warnings because they're more free-flowing. This is mostly harmless and a tune will only set those O2 limits higher.
A few of the higher end 100 cell exhausts (like the europipe, for example) have 2x the surface area and won't trigger CEL's.
Old Jun 13, 2011 | 04:11 PM
  #33
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
The surface area of the Europipe 100 cell cats is almost equal to the surface area of the stock cats. Hence if you're worried about smog inspection but want 100 cell cats, Europipe seems like a good choice.
Old Jun 13, 2011 | 04:19 PM
  #34
daytrip00's Avatar
Unless you live in CA... Then it doesn't matter as no aftermarket exhaust is CARB certified so you'll need to put the stock one back on to get it smogged. That or grease the palms of the mechanic to skip the visual inspection...
Old Jun 13, 2011 | 09:05 PM
  #35
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
I wouldn't worry about not passing smog with a Europipe. The exhaust is tucked up so tight and so well made it looks factory. I never had a problem with the smog inspection with mine.
Old Jun 13, 2011 | 09:25 PM
  #36
Duane996tt's Avatar
I just passed with a Speedtech that doesn't look anywhere near stock. No grease involved. Just a good Vietnamese smog technician.
Old Jun 13, 2011 | 09:34 PM
  #37
MikeR397's Avatar
MikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant future
What do you guys think? I know i'm in the minority here in not caring too much about the sound.
The sound from my catless EP2 Loud is more than enough to justify upgrading the exhaust for me. I'd have done it even if I didnt' get faster turbo spool or more horsepower, so those things are just bonuses .
Old Jun 13, 2011 | 09:36 PM
  #38
MikeR397's Avatar
Originally Posted by Nikolas
I noticed a significantly better throttle response when I added the exhaust after the flash. It definitely added more than 10-15 hp as that would typically be difficult to feel at the power level of a TT.
I agree, while a change in peak HP might be harder to feel the difference of, I thought the throttle response and turbo spool (faster boost) was greatly improved after my exhaust upgrade.
Old Jun 14, 2011 | 09:08 AM
  #39
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Get the exaust and your car will spool faster and sounds eager
Old Jun 14, 2011 | 09:19 AM
  #40
jspporsche's Avatar
jspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond reputejspporsche has a reputation beyond repute
Same thing as my wife after she gets an LV bag.
Jim
Old Jun 14, 2011 | 09:38 AM
  #41
rdss's Avatar
Jim
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
freddiemac
Oct 7, 2015 11:05 AM
poundsan
Oct 2, 2015 12:04 AM
