Traqmate RPM module & Camera Mount
Old May 30, 2011 | 12:29 PM
Boomers996tt's Avatar
Boomers996tt is infamous around these parts
Have searched a couple different forums for info and have seen contradictory info.
Has anyone connected a Traqmate RPM module? If so, where did you conncect it, ECU, OBDII, or coil pack?
Next, I don't have a harness bar or roll cage but would like to mount a camera on the inside. Have purchased a Delkin 2 knucle suction cup mount that I plan on mounting to the rear windshield but I'm concerned that this will be subject to vibration. Where have you track rats mounted cameras?
Using a JVC HDD Everio that works very well in my R56 using a Cruise Cam camera mount that mounts to the headrest posts.
Any suggestion on camera mounting would be appreciated.
Cheers!
Old Jun 1, 2011 | 06:54 PM
joe731's Avatar
joe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to beholdjoe731 is a splendid one to behold
I connected the RPM wires to the ECU, which is located behind the passenger side rear seat. Works perfectly. I think I found the correct wire info on rennlist. All pretty easy once you get into it.
adnanm3
Nov 22, 2023 02:43 AM
Rguy
Apr 12, 2020 11:11 PM
00aston
Dec 25, 2015 11:11 AM
jaehoppa
Oct 22, 2015 09:17 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
