h&r springs loose in the front
Old Jun 27, 2011 | 11:58 PM
kkswow12's Avatar
kkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nice
can someone tell me what is missing, i have the 29 385 h&r springs on front and back and the front springs are looose and flopping around when the wheels are off the ground, they are not attached to anything at the top, someone mentioned a pre tensioner? is missing and another said the springs use all stock porsche parts, only the springs are supplied by h&r...what is missing/ i just bought the car and previous owner is out of contact, thanks guys, kk
Old Jun 28, 2011 | 12:39 AM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
I don't know if anyone makes pretensioners (helper springs) unless it's part of a complete coil over set up. Attached is the front of a Bilstein pss10 at full drop. The smaller lower helper spring keeps the entire spring assembly in the perches. I had a similar problem with the rear Koni's on my 993. At full drop the spring would not be set in the perch at the top. I sent the shocks to koni and they added a larger internal bumpstop to shorten the shock shaft travel and keep the spring in the perch at full drop. I'd check with Bilstein who also makes the shocks for the H&R coil overs. They might be able to get you a front set of shock modified to hold the spring in place at full drop.
Old Jun 28, 2011 | 04:51 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
You can buy helper springs from Swift, among others.
Old Jun 28, 2011 | 10:22 AM
kkswow12's Avatar
thanks, but shouldn't this just work the way they sell the setup, i talked to h&r today and they say when they sell you a set of springs, that is all you get and it should just go in where the original springs were and the rest is porsche parts from original setup, and it seems i am missing one of the 3 large washer-type thingys that are at the top of the assembly, i'll get it figgered out, won't get TUV without fixing it, so...
911TurboRules
Jun 23, 2024 06:59 AM
Enemy
Nov 10, 2015 08:01 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
I'mAllIn
Sep 11, 2015 06:38 AM
The Oss
Aug 24, 2015 08:19 PM
