power loss on boost
Old Jul 22, 2011 | 09:54 AM
charlie1's Avatar
charlie1 is a jewel in the roughcharlie1 is a jewel in the roughcharlie1 is a jewel in the roughcharlie1 is a jewel in the rough
Power loss on boost
Thanks for the input guys!
Old Jul 22, 2011 | 10:29 AM
Bux996tt's Avatar
Bux996tt is infamous around these partsBux996tt is infamous around these parts
I am assuming no codes or CEL yet? I went down the same path as you. Same flash ran great in the beginning then issues. Found a split hose and it ran fine for a few days, now back at the shop with new/more codes pertaining to O2 sensors, though I don't think that is the problem. Working with Tony and my local shop to pinpoint the issue. Guesses at this point are plugs/coils or MAF.
Old Jul 23, 2011 | 11:01 AM
Bux996tt's Avatar
You can disconnect the MAF and run the car. You will get PSM/ABS code and check engine light, but no big deal. If the car doesn't stutter during a run with the MAF disconnected, I would say that is your issue. I just went through this. Put a new Bosch MAF on and reset the codes. Running great so far. Good luck.
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
nlakind
Nov 6, 2015 10:15 AM
PelicanParts.com
Aug 26, 2015 04:25 PM
PelicanParts.com
Aug 26, 2015 04:24 PM
