Quick answer on wheel size/offset needed
Old Jul 1, 2011 | 12:18 PM
jonty's Avatar
jonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to alljonty is a name known to all
will this fit my 8996 turbo without issue?
Front: 18x8.5
Offset: +56mm
Rear: 18x11
Offset: +45mm
Old Jul 1, 2011 | 01:51 PM
RiA's Avatar
RiA
RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !RiA Is a GOD !
OEM offset is:
8 X 18 ET50
11 X 18 ET45
The standard offset is a bit conservative in stance - many will use spacers to set them out closer to the fender lips.
With what you're looking at, the fronts will be tucked in a bit more than standard.
Old Jul 2, 2011 | 05:26 AM
jonty's Avatar
Old Jul 2, 2011 | 10:11 PM
SamboTT@ByDesign's Avatar
you can add up to 15mm spacers front and rear with no probs.
COBB Tuning
Jan 1, 2025 09:02 AM
alevine
Nov 4, 2015 10:05 AM
Fadi
Aug 21, 2015 03:43 AM
ModBargains
Aug 20, 2015 12:28 PM
pwdrhound
Aug 20, 2015 05:54 AM
