Best Track Tire?
Old Oct 13, 2003 | 10:06 AM
dmilzoff's Avatar
dmilzoff is infamous around these parts
Best Track Tire?
After running at Pocono yesterday, I find that the stock S-02A that came with my car (18" stock wheel) are OK, but only OK. I would like to get more aggressive, ie. 2nd set of wheels with dedicated track tires.
What are your recommendations if I want to stay with stock wheel size?
Old Oct 13, 2003 | 10:20 AM
SteveH's Avatar
SteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud ofSteveH has much to be proud of
if they're truly only track tires then hoosiers are the clear choice. for street and track go with the Pilot Sport Cups.
Old Oct 13, 2003 | 10:23 AM
dmilzoff's Avatar
Yes. I am looking for truely track tires. Where is the best place to get Hoosiers? What model?
Old Oct 13, 2003 | 10:29 AM
SteveH's Avatar
Old Oct 13, 2003 | 11:06 AM
Joe Weinstein's Avatar
get them heat-cycled...
Hi. Yes, the tirerack is the place. I'm not sure you want the
AS03 compound. You may actually want the RS03 for track.
And make sure you get the TireRack to heat cycle the tires
for you. It's done correctly and cheaply and makes a big
difference in the tire life and performance. You'll want fairly
high running pressures (low 40's front mid 40's rear).
Joe
Old Oct 13, 2003 | 11:24 AM
dmilzoff's Avatar
Looking up Tirerack's web site, they do not seem to have our stock sizes 295-30 and 225-40 x 18. I will call them to see if the Hoosiers come in proper sizes with matched diameter for the TT.
In your experience, are times noticably better? How many track days should I expect from a set of tires?
Old Oct 13, 2003 | 11:28 AM
these are the sizes you want
45820 P245/35ZR-18
45833 P285/30ZR-18
These have the right (same) diameter, and are right for
our stock wheel sizes.
You want them in the Rs03 compound
see www.hoosiertire.com
Joe
Old Oct 13, 2003 | 11:30 AM
SteveH's Avatar
track times will be night and day different. Depending on the track you can definitely expect to shave seconds off. The car will also feel 1000% better. Tire life totally depends on your driving style but i would say 3-4 track days is a decent estimate. . Call tirerack and they will hook you up and tell you what sizes you need.
-Steve
Jul 29, 2019 11:13 AM
horsepowerfarm
Sep 10, 2015 06:09 PM
Sales@RSW
Sep 3, 2015 09:34 AM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
The Oss
Aug 24, 2015 08:19 PM
