Time for yet another misfire thread
Old Jul 20, 2011 | 08:44 PM
Tiptronicus's Avatar
Tiptronicus is infamous around these parts
Just flashed my new-to-me '01 at 26k miles (owned it two weeks). Pretty sure the previous owner had yet to change the spark plugs. Its bucking me and threw a CEL (flashed, then stayed on the second time) at high RPM/boost under heavy acceleration. Hoping the signs point to spark plugs and/or coil packs.
Any reason I should be concerned?
Codes:
P0300 - misfire detection (total)
P0306 - misfire cylinder 6
P0305 - misfire cylinder 5
P0301 - misfire cylinder 1
P0302 - misfire cylinder 2
Thanks (and sorry about another freakin' misfire thread)
Old Jul 20, 2011 | 08:58 PM
raineycd's Avatar
Def do plugs and coil packs if you haven't. Coil packs are newer 997 part number.
Old Jul 20, 2011 | 09:00 PM
raineycd's Avatar
Oh and no reason to be concerned. More boost will show bad plugs much sooner... Do some searches about good plugs. The Bosch FR6-LDC would probably be a good fit unless you plan on doing some serious mods.
Old Jul 20, 2011 | 10:05 PM
and make sure you do both coils and plugs... and get better plugs....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 20, 2011 | 10:09 PM
ek9max's Avatar
ek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud ofek9max has much to be proud of
These cars need new coils at 26k? How long do coils last for?
bad107's Avatar
bad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond reputebad107 has a reputation beyond repute
what were the other codes you got?
Old Jul 20, 2011 | 10:18 PM
imagine doing the pugs.. getting n the car and finding out you still have some misfires... did you ever change the plugs? do you know how much labor is involved?
9.66
click to view
Old Jul 20, 2011 | 10:39 PM
raineycd's Avatar
They don't but the old 996 part is known for cracking and having issues. Cheap parts for the labor to get to them and when you do plugs, you have them out anyway...
After that, they should be good for a long time! Keep in mind this is a 10 year old car too! Plastic knows no mileage, but years add up!
Old Jul 20, 2011 | 11:16 PM
ard's Avatar
ard
If you are doing it yourself and don't mind hanging in the garage for 2,3 hours to redo it, skip the coilpacks. 26k and 10 years is not a crazy heat/life exposure. I went 40k with my 2004 and zero issues. YMMV
If you are PAYING someone else, I'd just do it. Cost is only the part price, labor is $0 for installing new coils with a plug change. The labor price for whole job is ~3x the cost of the coils
A
Old Jul 20, 2011 | 11:27 PM
ek9max's Avatar
Ya I had no idea it was such a chore for the plugs... My bad.
Old Jul 21, 2011 | 12:44 AM
harkerdude's Avatar
harkerdude is infamous around these partsharkerdude is infamous around these parts
Had same issue at 27kmi
I got CEL for misfires.
Just did 30k service early w/ new plugs and coil packs.
All those symptoms are gone and car pulls smooth and no jitters at idle.
can't be happier at the moment.
hope you get it sorted out.
Old Jul 21, 2011 | 08:12 AM
POMFG - unexpected dent detected. Thanks Ben.
Old Jul 21, 2011 | 09:47 AM
REVS11's Avatar
REVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond reputeREVS11 has a reputation beyond repute
NGK BKR7E is a popular plug as well. Worked for me.
The job is not too bad.
Remove rear bumper.
Remove rear parts of wheel well lining.
Remove intercoolers.
Use a couple of long extensions to a 1/4 ratchet, to remove and replace coilpacks and plugs.
Or just have a shop do it.
My coilpacks were all fine at 70k miles. I swapped them anyway while I was in there.
Old Jul 21, 2011 | 11:24 AM
Do plugs and 997tt coils.
#TeamAIM
Old Jul 22, 2011 | 01:47 PM
Remove rear bumper.
$1,070 to do just what you suggested. 5hrs labor. Except he said I should use (and installed) the NGK BKR6E (at $15 a pop, no less - nice markup!!). Told me the NGK BKR7E aren't beneficial until you get up into 20psi+ boost area.
Keeping my indy in business is what I do best. At this rate, I may just buy a second TT to practice working on. It may end up being cheaper in the long run.
