Do PCCB's improve acceleration also? (reduced weight)
Old Apr 20, 2005 | 04:22 PM
teutonictrio's Avatar
Banned for Eternity
teutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond reputeteutonictrio has a reputation beyond repute
Obviously they help with cornering as the weight reduction is unsprung weight, but I wonder if because they are lighter overall as well if it will help somewhat in acceleration, as any lightening procedure of any significance should also do?
Old Apr 20, 2005 | 04:49 PM
buddyg's Avatar
Minimum at best. On the quarter mile they figure every 100 lbs you save in weight is worth 1 tenth of a second. Or adding 10 hp is worth 1 tenth.
Old Apr 20, 2005 | 04:52 PM
LUISGT3's Avatar
-100lbs=10hp?
Old Apr 20, 2005 | 05:26 PM
HotRodGuy's Avatar
well, not the hp/weight scenario changes significantly when you start getting into fast cars
Old Apr 20, 2005 | 05:35 PM
Life Dies's Avatar
Life Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud of
In Rotational Mass (intertia), I am certain different logic applies.
Old Apr 20, 2005 | 06:07 PM
cig1's Avatar
Wannabe
cig1 is infamous around these parts
Re: Do PCCB's improve acceleration also? (reduced weight)
I would think acceleration should be significant, but I don't understand how they would help cornering.
G
Old Apr 20, 2005 | 07:14 PM
Joe Weinstein's Avatar
yes they should help everything. They help acceleration
because of the light weight, *and* because this is rotational
weight the polar moment is smaller so the disk provide less
resistence to spinning up. Lastly, they help handling because
they are unsprung weight (less) so after a bump, the
suspension can push the wheel back down onto the road
quicker. The tire stays on the road and you get more stick. The
shock absorbers need less damping too.
Joe
Old Apr 20, 2005 | 08:51 PM
PMac's Avatar
PMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to beholdPMac is a splendid one to behold
It should help somewhat. Hard to know the magnitude of the effect, but think of the physics. An engine is a device for putting out energy (power being energy per unit time). So, where does the energy from the engine go when you hit the gas in a straight line?
1) Heat (engine/tires etc.)
2) Overcoming friction in the drivetrain (hence dyno RWHP numbers being lower than flywheel HP)
3) Pushing air out of the way
4) Spinning up the rotating components of the drivetrain (all the way from the crankshaft to the wheels, including the brake rotors)
Total engine energy is the sum of those, so when you put on the PCCBs, the 4th one is reduced, leading to an increase in the other three, which requires you to be going faster. This is why people put lightweight flywheels on their car (well, one of the reasons anyway). This is also why the F1 teams don't win any races with 24" spinners.
And everything Joe said about handling benefits was spot on, too.
Old Apr 20, 2005 | 09:15 PM
aj996tt's Avatar
aj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond reputeaj996tt has a reputation beyond repute
Well, my Turbo S feels a heck of alot faster than my '02 Turbo. How much of this seat of the pants difference is due to the seemingly underrated X50 versus the PCCB is for practical purposes untestable. I do notice that the car feels *lighter* on turn-in and seems to *set up* for corners more easily.
Unrelated, but it also seems that the speedo is more accurate and less optimistic than in my previous car.
ModBargains
Bentley Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
Texas1
Sep 20, 2015 09:12 AM
