obd II p0638
Old Aug 12, 2011 | 02:04 PM
arortiz's Avatar
arortiz has a spectacular aura aboutarortiz has a spectacular aura aboutarortiz has a spectacular aura about
obd II p0638
Recently installed a 70mm IPD plenum and throttle body on my 02 996tt. Performance wise, I noticed more mid range "pep". Later while on an aggressive drive with a Mustang gt500 I lost acceleration and my check engine light came on. Car went into limp mode so I shut it down, and back up again, it operated normal but check engine light still on.
Took it to independent shop and the obdII code P0638 Throttle Actuator Control Range/Performance (Bank 1) shows up. Çhecked all vacuum hoses, all ok.
Anyone have experience with this code? What does the "throttle actuator look like?
Old Aug 12, 2011 | 08:30 PM
seen it happen... whos IPD and whos TB?
most probably a boost leak...
take the Y pipe off and pressure test at the TB... I bet you find some big leak...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 13, 2011 | 07:09 AM
arortiz's Avatar
boost leak
Markski thanks for the reply! How far (safely) can the engine be lowered from the two bolts that attach to the engine mounts? I would like to check the back side of the rubber sleeves that attach the plunum. I suspect that that is where the leak is. Thanks a bunch! Still enjoying the heck out your exhaust!
pwdrhound
11
Nov 25, 2015 01:18 AM
Oct 6, 2015 06:13 PM
justthebest
Sep 26, 2015 09:28 PM
justthebest
Sep 19, 2015 11:32 AM
WheelsupZR1
Sep 19, 2015 06:46 AM
