Best Video / Data Acquisition System
Old Sep 15, 2015 | 10:15 PM
justthebest's Avatar
justthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud ofjustthebest has much to be proud of
Anyone have experience with a good video / data acquisition set up? I've seen multiple products out there, but either the video is sub-par or the data is GPS-only, instead of OBD-read RPMs / Accel / Brake / etc.
TIA
Old Sep 22, 2015 | 07:14 PM
Est8esq's Avatar
Est8esq is infamous around these partsEst8esq is infamous around these parts
Depends on how in depth you're looking to go?
I suck at technology and want simple. Went w/ smartycam and Aim Solo DL. Plugs into obdII port and is simple.
If you're working w/ professional coaches that are looking to download and really get into data analysis, then you should look at Motec.
Old Sep 23, 2015 | 08:09 AM
pwdrhound's Avatar
I
TIA
I use Motec dash/logger for data. It is an excellent tool and highly recommended. The data is limitless, it's really amazing. Mine is wired in to the CAN bus with several external sensors. I recently added an Aim Smartycam2 and the video is very good. You can overlay the data from the Motec via the Aim ECU bridge. I'm local to you and one of the best Motec guys is in Denver. He did my install and set up. He's always there to help with any questions either at the shop or the track. You can see the video quality below. I did not have a chance to program the ECU bridge prior to this so that is why no data is overlayed. Make sure to select 720HD on the YouTube video as often it defaults to a lower quality. Also turn up the sound on your computer. I plan on adding an external Aim microphone.
Old Sep 26, 2015 | 08:51 AM
viprklr's Avatar
viprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond repute
Alway seems like you trade one for the other. Sucky subprime video or less data. I use Harry's Laptimer Pro & simply mounted my iPhone on the roll bar with an IOport mount. Harry's will now integrate my GoPro & use the Gopoint for data acquisition. Less than $200 for everything.
Old Sep 26, 2015 | 09:28 PM
ipse dixit's Avatar
ipse dixit is infamous around these parts
Porsche Track App (assuming you have the Sport Chrono pkg)
mlife2878
Aug 26, 2015 07:02 PM
