ksport coilovers
#61
I don't know if Manalex still posts in this section but he had a set of K-sport coilovers on a 996 race car, have taken a ride in it, I thought they felt pretty good for off the shelf. He's been running them for a few years now with no problems that I know of.
I'd rate them just below JIC (of course I have thousands of miles and hundreds of laps on two different sets of JIC)
And I'd rate the JIC just below the KW V3, because of the quality of materials used, serviceability and adjustability. However my custom valved JIC more than get the job done in the handling department.
This is of course a track rating, on the street, none of them are great (Moton is king for the street/track combo IMO).
#62
We like KW, going to be installing a set in the shop GT2 as soon we have time. The set of Variant 3 is already at the shop. If you guys have any questions, please let me know. We have been selling KW for over 10 years & are one of their largest accounts.
#64
I am on it for few months now, as my friend is one of the dealer so I gonna have a try, so far it is stiff and quite ok to me, but maybe I have set the car in aggressive camber and adjust the coilover to quite hard way, they are not too comfort at all. Besides, on my frd's BMW, they perform well also and seems a lot comfort than mine...
#65
#66
I am on stock hollow rims for going track, R888 or A050 on all corners, F 34, R 42lbs pressure, adjusted it to F24 R28 (36 is the most stiff) ran couple months now and feeling too much for the street. Have it adjusted last night to F18 R20 to see how it works...
#67
So far no problems here. I've had mine since September, and I haven't had any issues. I wanted the car lowered with a bias to a softer ride (my wife didn't appreciate the stiffness of the OEM touring suspension). This car won't see any track time, but when I have occasion to take a corner faster, the Ksports don't seem to alter the handling. My set were even used (yes, I broke a cardinal rule, but $500 was to good to pass up). Hope this helps.
#71
I helped a friend install a set. I thought the build quality was there. My only complaint was the amount of rear shock adjustability was not enough without messing with spring preload. They ride on par with my H&R coilovers. For an entry level coilover setup with solid upper camber plates they are nice IMHO. He can comment further.
#72
I installed a set a few mos ago with the help of VAGscum and have enjoyed them immensely. They appear well made, although time will tell, and the ride is much better than the lowering springs I previously had. While Im much lower than stock and on 19's, I dont have to slow down for rr crossings or road imperfections anymore.
The kit was almost complete as the factory nuts are not the same pitch or thread as the supplied threads, so make sure to get some before starting the installation. I like that the ride is adjusted by the lower mounting point, not the spring load as with many other coilovers (see below for more on this*). The front camber plates are a little hard to get to as they sit below the mounting holes, however, with a ball type alen wrench, they are workable.
I would rate the whole package as an 8.75% out of 10 for the following reasons:
1)weak instructions. (Lacking info that a first timer may need)
2)wrong pitch/no nuts. (Really? its a Porsche kit right? just proves our parts must fit other cars as well)
3)design of the camber plates- although not needed for stock plus alignment, could be better designed..
4)camber plate mounting bolts a hair to long and pressing on trim peaces.
5)*Rear lower mounting cups should be longer/deeper -- They are about 5 inches deep and how you adjust height. I wanted the shock atleast 1.5 inches into the cups for structural reasons, however, I only got a little over an inch in order to get the correct ride height and started using spring preload to get higher. Now, Having driven on them for a while, I want to add more spring preload and keep the same ride height so I may get to the 1.5 inches I want. (again better instructions would help)
All in all, I read lots of good reviews about them in the BMW, Jap car, and even the Boxter forums, so since I no longer run Auto-x or HPDE events, I felt them good enough for road use and as long as they hold up, I would do it again.
Hope this helps.
Scott
Hope this helps.
Scott
#73
I've had them for about 5k miles now, Im very happy with them so far; I don't track my car but i have no doubt they could handle track duty. At the price point you really can't beat them, They cost less then a set of shocks alone and they are rebuildable/adjustable
#75
It's easy to install. The only thing you have to be careful is how you setup the sway bar end links. If set up wrong, you'll rub front axle at full lock.
I've been through 2 winters in NE(exhaust components rust) and over 30k miles now. No rust, non of the adjustments components have seized(I've recently adjusted height), still feels like it did when installed). Hopefully it'll last many more miles/years
