P0139 o2 sensor
Old Aug 23, 2011 | 07:16 PM
REDLINER911's Avatar
REDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud of
P0139 o2 sensor
Hi, I just got an '01 turbo two weeks ago and just had a CEL come up. I had a PPI and there were no codes when I bought the car.
Checked it with the OBDII and found this:
P0139 Aging of Oxygen Sensor After Catalytic Converter (Cylinders 1 - 3)
also described as O2 sensor circuit slow response (Bank 1 sensor 2)
Car seems to be running just fine other than the light. My ideas are to either:
1) disconnect the battery and just hope that the code does not come back
2) Clean the MAF? Could this be a possible fix?
3) Buy a new O2 sensor from Amazon, Bosch 16205. But the car only has 46k miles and it seems very early for an o2 sensor to go bad
Any suggestions?
Old Aug 23, 2011 | 08:47 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
Is the car stock or modified?
Old Aug 23, 2011 | 09:34 PM
bensonJ's Avatar
bensonJ is infamous around these parts
Aging faults on O2 sensors almost always mean you need a new one.
Ben
Old Aug 23, 2011 | 10:10 PM
car is stock
Old Aug 24, 2011 | 12:11 PM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
Replace both the pre cat and the post cat sensor on the driver side. Usually when one fails, the other is not far behind it on that same bank.
Clearing the light is not going to solve the issue, if it came on, there is a problem and the light will just come back on eventually.
Old Aug 24, 2011 | 11:17 PM
Thanks for the suggestions
vogz
Oct 8, 2015 12:02 PM
Frank ( Sunnyside )
Bentley
Oct 3, 2015 11:13 PM
Oct 2, 2015 02:23 PM
Oscar 987
Sep 29, 2015 04:57 PM
ECS Tuning - VW
Sep 28, 2015 03:19 PM
