What mods for engine built up?
Hy everbody,
My 996 Gt2 currently has about 650hp on stock engine. I plan to buy a 996 TT engine to rebuilt it with forced parts.
My plan is to run gt30 oder 35 turbos and get over 1000 hp on E85. What parts do you recommend? Do I need to change the crank? pistons? what modification of the cylinder head are needed?
I want to put my orig. GT2 engine with k24 on the side to have the possibility to change if something brokes on the turbo engine.
Thanks for the help,
Rony
Rony
are you just running e85 or will be running pump also? At the power you are looking for you will need some items, oil pump, rods, mild head work, case work, stock crank will work depending on rpm's you will run, head studs and you will need to run the 997 intake plenums. Fuel system is a must also.
Thanks for the answer.
I want to run pump gas also.
I dont want to raise the rpm too much max. 7500 U/min. My fuelsystem is allready very strong.
My plan was to use pauter rods, headstuds, harder springs, small headwork, gt3 cams.
what oilpump do i need?
what do you mean with case work?
nless your talking about OEM cams regrinded then its a diff. story...
2001 996TT 3.6L and stock ECU
Jul 29, 2019 11:13 AM
turbotuner20v
Sep 11, 2015 12:02 PM
