How urgent is it to replace the ISB in a 996TT
Old Sep 8, 2011 | 05:56 PM
BOOSTTT's Avatar
BOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to behold
I'm just wondering if I should be very concerned about the many things I have been hearing about intermediate shaft bearing failure on the 996TT. I here it is a much bigger issue on the boxters and non turboed 996's, but I do not want total engine failure w/o any symptoms???? My mechanic says they have new ceramic bearings now with a constant oil flow to them...No longer use sealed bearings. Just wonder how urgent this should be. He said 2K for the "fix". Any input would be appreciated. Thanks!
Old Sep 8, 2011 | 06:48 PM
VAGscum's Avatar
The IMS bearing on the standard NA 996 is a ball type bearing and the bearing on the 996TT, GT2 and GT3 are of the bushing type. The NA 996 has an upgraded bearing to fix it. The dry sump 996TTs are still using the same IMS bearings they came out with. The bearings are not an issue on the 996TT. The woodruff key and the IMS to crank gear lash is a nuisance due to the noise. But neither are a documented failure point.
Old Sep 8, 2011 | 07:08 PM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
Does your mechanic work on many TT's. My mechanic states that there is no fix that permanently eliminates the IMS gear chatter. He also stated that it is nothing to be concerned over unless the noise is apparent in all RPM ranges. Considering his experience, I trust him completely.
Old Sep 8, 2011 | 07:48 PM
John@SpeedTech's Avatar
It's not 2K for the fix on a 996TT - the entire engine has to be torn apart, case split, etc. to get to the bearings - I would figure at least 10K. As far as this repair is concerned, I would wait for it to happen and then deal with it...it doesn't make sense to try to do bearing replacement in advance of failure.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
BOOSTTT's Avatar
OK. I thought the 996TT's had the same bearing as the 996 N/A's, but if they are different, that would explain why I have also heard the TT's have less problems. The mechanic works on nothing but lambo's ferrari's, Porsche's and mercedes and such. He must have been talking about the 996 N/A's when I asked him about the bearing issues. Thanks for the input.
Old Sep 8, 2011 | 08:40 PM
Yes, the 996NA's are replaceable - the TT's are not.
2022 Cayenne White
Old Sep 10, 2011 | 05:10 PM
Tim941NYC's Avatar
2K in tools alone..
Old Sep 11, 2011 | 12:45 PM
kkswow12's Avatar
kkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nice
and when the noise is constant
the end is near...
gulf gt
Aug 27, 2015 10:27 AM
bmwtmx
Aug 26, 2015 07:26 AM
00aston
Aug 24, 2015 09:29 AM
John@SpeedTech
Aug 23, 2015 12:07 AM
