My Billet 16 DYNO (by EPL)
Old Sep 23, 2011 | 02:36 AM
  #46
heavychevy's Avatar
Originally Posted by Blockhed
why mod if you only drive 1200 miles a year, no offense meant just never understood that. And heavy don't bother with baby snails, you'll love the Alpha 28's, listen to Mark. Plus with you tracking the car the damn tq at idle will have you sliding all over the place.
Tony told me he can tune the car to not have so much Torque. I want peak torque to be about equal to peak hp. About what the Switzer Billet 16 dyno looks like.
Although the top end of the A28 is alluring. I likes me some top end, but I want the car to drive more like NA so instant boost off the corners. At the hp I'm looking at, I doubt I'll see much of a difference on the top end most places.
I don't know, I've changed my mind 17001 times already, it could change a few more before I'm ready.
Old Sep 23, 2011 | 05:57 AM
  #47
Lennon31987's Avatar
Lennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond reputeLennon31987 has a reputation beyond repute
I have a few cars to play with and lots of things going on in my life. No offense taken.
Old Sep 23, 2011 | 06:00 AM
  #48
exactly i could have had same hp same tq number as well, I prefer this tune.
Old Sep 23, 2011 | 09:32 AM
  #49
johnspeed's Avatar
Hi,,Good Numbers and curve..I am suprised EPL/Tony did not require an additional fuel pump to be added to tune for more HP/TQ with your set-up??
Old Sep 23, 2011 | 09:50 AM
  #50
why? current set up is doing the job, no 5 bar just 72lbs injectors
Old Sep 23, 2011 | 10:06 AM
  #51
orygunturbo's Avatar
orygunturbo is infamous around these parts
540 on Tony's dyno is pretty amazing. Is your car RWD?
I've seen comments like this in a couple of threads. What's so special about Tony's dyno? Isn't it a Mustang like many others that are around?
Old Sep 23, 2011 | 10:30 AM
  #52
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
Mustang's like any other dynometer can be calibrated, so no dyno, even from the same manufacturer will read the same unless you don't calibrate it and leave it at the settings delivered by the manufacturer. Yet another reason why comparing numbers between different dynos is a waste of time. Always refer to the delta change which is the most important number. If you don't get a baseline done first, you have wasted your time on the dyno.
Old Sep 23, 2011 | 11:24 AM
  #53
johnspeed's Avatar
I have The k24/18gs,72 injectors and when Tony retuned my car on Kelly Moss's Mustang dyno,,,, he said I needed more fuel and to add another pump,which I did, so he could get more out of it...You have a great package and I would have thought with those good numbers you would have been out of fuel......Just trying to compare,thats all...thanks.....
Old Sep 23, 2011 | 12:02 PM
  #54
More than likely I could benefit from it, I am sure Tony would agree with that. But...its not a necessity for me at this point
Old Sep 23, 2011 | 12:28 PM
  #55
I get that. I've dynoed my share of cars before. There are SAE guidelines for dynos so what your saying is that all the other Mustang dynos except for Tony's is calibrated incorrectly? I find that hard to believe.
Old Sep 23, 2011 | 12:29 PM
  #56
Just log your duty cycle at full tilt. That will tell you if need upgraded system.
Old Sep 23, 2011 | 12:35 PM
  #57
johnspeed's Avatar
Agreed,,,you are right......
Old Sep 23, 2011 | 12:49 PM
  #58
2nd fuel pump is not in question at all, if it was needed it would be there already. thanks.
Old Sep 23, 2011 | 02:46 PM
  #59
heavychevy's Avatar
Lennon, any plans for a 60-130 or drag run?
Old Sep 23, 2011 | 05:08 PM
  #60
ttboost's Avatar
Yep. My car had made over 600rwhp on Tony's dyno with 18g's, 1 stock fuel pump, 72lb'ers, stock airbox and meth...Not saying I would've gone further, but it was fine as it was. I would love to see 60-130 numbers too....
