Headers, Headers and more Headers
Old May 1, 2005 | 04:35 PM
  #46
cjv's Avatar
cjv
Moderator
Originally posted by Kevin
With stock K24's, I'm betting that the car actually lost torque till 4000 +/- 500 RPM.. After that it should pull ahead..
Is your bet based on just installing the headers or installing and adjusting the afr's? Also .............. coated and/or wrapped or no insulation? Oh, so many variables.
Old May 1, 2005 | 06:48 PM
  #47
cjv's Avatar
cjv
Moderator
Come on Chad, you know the truth... (smile) We also know the application in which these headers will perform.. The build quality is top notch!
Yep, it's all directly related to the impeller type/size and backpressure at the bung located immediately after the kats.
Old May 1, 2005 | 08:35 PM
  #48
olslategray's Avatar
olslategray is infamous around these parts
Thumbs up
I am not a racer but I do have S-Car-Go headers, S-Car-Go carbon air intake, rebuilt my stock turbos with garret ball bearing turbos and a GReddy Boost Controller. I have NO lag. It is hard not to have the boost even with a light touch to the pedal. I am very pleased with the S-Car-Go upgrade I have.
Old May 1, 2005 | 11:05 PM
  #49
Jean's Avatar
Jean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond reputeJean has a reputation beyond repute
CJV thanks for clarifying the gear ratios used, great choice. The stock 996 TT 1st. gear is 3.818 993GT2, Clubsport and others came with a taller 1st. gear (3.15) and 2nd. (2.0). The 996 GT2 is the same as the 996 TT I believe.
Old May 1, 2005 | 11:29 PM
  #50
cjv's Avatar
cjv
Moderator
Jean,
I don't remember all my gear ratios off the top of my head, but I'm sure they are posted somewhere in the cjv/s car go thread.
Old May 10, 2005 | 04:01 PM
  #51
KPV's Avatar
KPV
Kevin,
Please elaborate.
Old May 10, 2005 | 04:04 PM
  #52
BCS996TT's Avatar
BCS996TT is infamous around these parts
what were the numbers???? It cant be that bad! Spill it!
Old May 10, 2005 | 04:12 PM
  #53
Erik@Cargraphic's Avatar
Erik@Cargraphic is infamous around these parts
come on Ken...give it up!
Old May 10, 2005 | 04:31 PM
  #54
cjv's Avatar
cjv
Moderator
You guys ought to know by now what Ken does he does correctly. You don't simply bolt headers on and drive away. Ken also does great reports when he is finished.
Old May 10, 2005 | 07:27 PM
  #55
cjv's Avatar
cjv
Moderator
Chad, like I said earlier, with the combination that he is running he lost power. The turbine wheel stalls.. To fix his loss, he has 2 choices. Have Scargo decrease the ID of the primaries. Or keep the headers and run K16's with larger compressor wheels.. Velocity of the turbine wheel is the key.
Kevin,
I don't know the details of Ken's set up and depending on his set up, yes your suggestions are two distinct options. I have also used other options with very good success. Namely, insulating the heads and tuning the motor to the headers.
I have run smaller and larger headers on my car. My problem was a little different. The smaller headers produced better power in the lower 4000 rpm range, however lost power after compared to the larger diameter headers.
I found insulating the headers was like finding free power. In addition, I'll bet the S Car Go headers are making the motor run leaner. Add fuel and the power will come way up.
I don't know what Ken is running for an intake, however another way of taking advantage of the S Car Go headers is to use the S Car Go carbon fiber intake. This intake by itself will produce another 25 hp and coupled with the headers will further eliminate the stall you refer to.
Old May 10, 2005 | 07:38 PM
  #56
Zippy's Avatar
Chad, like I said earlier, with the combination that he is running he lost power. The turbine wheel stalls.. To fix his loss, he has 2 choices. Have Scargo decrease the ID of the primaries. Or keep the headers and run K16's with larger compressor wheels. Velocity of the turbine wheel is the key.
Would the EVO/IA stage 4 GT turbos meet this description? Aren't they a K16/24 hybrid?
Mike
Old May 10, 2005 | 08:36 PM
  #57
I have a pair of headers from kevin.... very nice....
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old May 10, 2005 | 08:47 PM
  #58
cjv's Avatar
cjv
Moderator
Mike, K16/Garrett hybrids does meet what I said. However, all Ken has to do is grab a set of stock headers, grind the inside welds like this..
http://forums.rennlist.com/rennforum...6TT+header+DIY
All his power an more will come back..
Kevin,
I believe we all need to sit tight and see what Ken comes up with. The stock headers even ported, start to lose ground to S Car Go type headers at about 560 hp.
To simply bolt on each header and see which one makes more power is moot. Without tuning the ECU and removing weak links prior to the heads for each exhaust it's impossible to know which system makes more power. Moreover, power is not necessarily our ultimate goal, otherwise we would have used straight through design. It makes alot more sense to measure exhaust gas backpressure and monitor boost pressure during a dyno pull. Measuring backpressure is a straight forward indication of how good an exhaust is, and looking at the boost we also get an idea of the throttle response characteristics and the source of the added power.
Old May 11, 2005 | 02:11 AM
  #59
sharkster's Avatar
yups.... he knows what's what...
Old May 11, 2005 | 02:24 AM
  #60
The stock K24 compressor wheel starts to run out of steam right above 5500RPM. A larger compressor wheel would allow more air to help this situation.
YES I AGREE- i had the k-24s race versions and anything after apprx. 5500 rpms the car was out of air.. and I actually felt it. Kevin knows... My dyno run proved it as well.
9.66
click to view
