Installing GT3 Seats...(stripped an overtorqued bolt)
I took out my passenger seat for the texas mile last year and used a too powerful impact driver for the job. Now my bolts are overtorqued in there and a couple of the heads are stripped.
Any ideas of how to get the bolts out other than drilling them out? I just want to be able to reuse the hole.
Also, anyone have extra bolts lying around?
Thanks!
Thanks!
A big-*** easy-out, which requires some drilling.
Can soak it a bit in PB blaster..
Or you can use the gator socket (its a socket with a bunch of steel pins inside that will grip rounded bolts) - http://www.amazon.com/Gator-Grip-ETC.../dp/B000065CJ8
A small pipe wrench if you can get it on there =/
GL
GL
i just did the exact same thing, the 2 bolts on back side of drivers seat were just TQ'ED in dere, a friend with air tools managed to get a socket on them, i stopped before ai totally destroyed the heads, my next stop was the drill and the B A easy out as well,,, got lucky and got gt3's...they're a WoW
sorry no bolts but good quality 6 point socket would be good start & there are bolt extractors that are a socket w/ a swirl inside that work well too.A good old tap should clean the the treads up & the bolts are nothing special & should be available at your local hardware store
04-28-2022 12:38 AM
Rez90
08-24-2015 09:53 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-20-2015 02:37 PM
