Coding out fixed wing error code (questions about searched content)
Old Oct 13, 2011 | 11:25 PM
FlyingGuy's Avatar
FlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant future
main thread in question https://www.6speedonline.com/forums/...ror-codes.html
this is what im referring to :
Originally Posted by v35
From the Aerokit Installation Instructions TSB 1/05 6658:
Connect PIWIS tester and switch on ignition.
Select vehicle and Rear control unit.
Select Coding, then Spoiler and code fixed spoiler.
couple questions
1. Since this is pulled from the "Aerokit Installation", does that mean i need the aerokit harness for the 996tt?
2. If that does NOT mean i need the harness, can anyone CONFIRM that this has worked? That thread ended up kinda going off track, so no one ever said they actually had a tech do it.
thanx. work is slow tonight....
Old Oct 14, 2011 | 10:16 PM
Tim941NYC's Avatar
You can use the gt2 harness (same as aero) for the deck lid. It just plugs in and no error code should come up, this is for fixed wings though. I remember a pin out that was posted that shows what to jump to bypass buy the harness.
Old Oct 14, 2011 | 10:19 PM
FlyingGuy's Avatar
ive priced out the harness, and am prepared to go that route. but if there is a proper DIY or a code-out procedure that can be done with a fixed wing, id rather do that.
Old Oct 14, 2011 | 11:02 PM
Tim941NYC's Avatar
Yes search it.. Some one may have saved it and can re post it.
Jul 29, 2019 11:13 AM
oddjob142
Aug 24, 2015 05:49 PM
silver86
Cayenne 958
Aug 21, 2015 03:08 PM
Aug 19, 2015 06:55 PM
