Dirty Fuel Filter
Old Oct 15, 2011 | 06:37 PM
Yazz911TT's Avatar
Yazz911TT is infamous around these parts
Dirty Fuel Filter
This is the result of my fuel filter after only 6/7K miles. 3 Weeks after buying my car it had a spluttering issue and it was a clogged fuel filter, that got changed and i had no problems since, and then after discovering that was the issue I kept a mental note to regularly change the fuel filter, I thot every 10K would be sufficient but as the car was going to be having some upgrades I thot I may as well do all service items while i'm at it, undid the fuel filter and this is wot came out...
Do i have dirt in my fuel tank?? SHould I remove my fuel tank and clean it out??
Old Oct 15, 2011 | 08:25 PM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
I am going to change mine out.
Old Oct 15, 2011 | 09:09 PM
ZIP22's Avatar
ZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond repute
Changed mine out recently after 30K and the fuel was very clean. Are you sure it's dirt? Maybe it's from your fuel tank, fuel pump parts failing, or bad batch(es) of gasoline?
Old Oct 16, 2011 | 09:55 AM
Yazz911TT's Avatar
How do I narrow it down to which one of the above you mentioned it is??
I know that I use the same fuel station and the same pump at that station 95% of the time I fill up. So could it be that??
Old Oct 17, 2011 | 05:07 AM
winnigt2's Avatar
winnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond reputewinnigt2 has a reputation beyond repute
it could be your fuel station.....fill up a separate fuel sample and analyse it
but you schould clean your tank and check fuelpump
Wheeler
Sep 22, 2015 08:02 PM
Lucid Moment
Sep 12, 2015 01:12 PM
sparks
Sep 8, 2015 03:03 PM
ship it
Sep 7, 2015 10:49 AM
DLF
Cayenne Turbo
Sep 3, 2015 01:36 PM
