ABS/PSM - 4200 code
Old Oct 17, 2011 | 03:19 PM
silentbob's Avatar
silentbob is infamous around these partssilentbob is infamous around these parts
ABS/PSM - 4200 code
I've been getting the ABS/PSM errors now pretty regularly and the durametric pulls a 4200 code - right front speed sensor. I replaced it with a new one, but lo and behold, I'm still getting the error.
Any suggestions for where else the issue could be?
Old Oct 18, 2011 | 02:53 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
911 Turbo (996)
4503 Fault code 4200
45-7
page 1
PSM 5.7
4200ps05
45
Printed in Germany – 29, 2002
45-7
Fault code 4200
Speed sensor lead, front right
Diagnostic conditions
Ignition on
Possible cause of fault
Short circuit to B+ / ground or open circuit between control unit
and speed sensor
Speed sensor faulty
Control unit faulty
Affected pins
Pin 15 and pin 16
Diagnosis/troubleshooting
Work instruction Display OK If not OK
1 Visual inspection
Examine speed sensor and
wire at the front right for external
damage.
Check speed sensor plug for
corrosion.
Step 2 Repair speed
sensor and
lead.
Repair speed
sensor plug.
End
2 Checking speed sensors
Ignition off.
Disconnect plug from speed
sensor.
Measure resistance between
pin 1 and pin 2 on speed sensor.
1 k
Ω to 3 kΩ
 Step 3
> 3 k
Ω or < 1 kΩ
Step 9
3 Checking function of
speed sensor
Ignition off.
Set AC measuring range on the
multimeter.
Jack the vehicle up and turn the
front right wheel by hand.
Measure voltage between pin 4
and pin 5 of speed sensor.
Measureable AC voltage,
approx. same
level as to speed
sensor of an opposite
wheel at same
wheel speed.
Step 5
No AC voltage
measureable.
Step 5
4 Mechanical function
Check speed sensor and
toothed ring at the front right
for soiling and damage.
Step 9 Clean toothed ring
and replace, if necessary.
End
45
5 Checking leads of speed
sensor for short circuit
to B+
Ignition off.
Pull plug off the PSM control
unit.
Ignition on.
Measure voltage between PSM
control unit plug pin 15 and
ground.
control unit plug pin 16 and
ground.
< 0.3 V
Step 6
Short circuit to B+
between PSM control
unit plug pin 15
or pin 16 and
speed sensor pin 4
or pin 5.
Repair wiring harness.
End
6 Checking leads of speed
to ground
Ignition off.
PSM control unit plug pin 15
and ground.
PSM control unit plug pin 16
and ground.
∞ Ω
Step 7
Short circuit to
ground between
PSM control unit
plug pin 15 or pin
16 and speed sensor
pin 4 or pin 5.
End
7 Checking leads of speed
sensor for open circuit
Ignition off.
and pin 4 on speed sensor.
and pin 5 on speed sensor.
Ω
Step 8
Open circuit in
leads of speed sensor.
End
8 Checking leads of speed
with respect to each
other
Ignition off.
and pin 16.
∞ Ω
Step 10
Short circuit in
with respect to
each other.
End
Replacing front right speed sensor End
10
Replacing PSM control unit End
Its a bit difficult to follow , but its coppied from a PDF file and comes out like this when pasted.
All the info is there though.
Old Oct 18, 2011 | 05:28 AM
heavychevy's Avatar
I have the same issue, only I have actually had my ABS fail (on track, multiple times). Replaced the harnesses and the sensors. Still problem. I have been instructred by someone with similar issues to check the ground wire (two brown wires used to ground the ABS/PSM system in the boot lid). That is my next shot. Then I'm going to rip the whole thing out.
Old Oct 18, 2011 | 07:15 AM
ukgatecrasher's Avatar
ukgatecrasher is infamous around these parts
I had the exact same issue after initially changing the sensor.
Bought a harness repair kit from OPC and all was good :-)
Old Oct 18, 2011 | 07:58 AM
I know I keep going on about this, but, have you had your steering angle sensor recalibrated. That will bring up ABS/PSM failure. check for that specific code with durametric.
Old Oct 18, 2011 | 08:52 AM
silentbob's Avatar
Wow, thanks for all the suggestions guys. I will follow the diagnostic instructions and post results.
Sunnyside - The previous owner had steering angle sensor replaced and recalibrated and the durametric only shows 4200 as the code. There are no other codes from the ABS/PSM unit. If it was the steering angle sensor, I should expect to see a code pointing me in that direction right?
Old Oct 18, 2011 | 09:03 AM
Yes , it has its own unique code. You would know if it was that problem.
This ABS thing seems to be the 996tt's achilles heel. I had 2 brand new tyres fitted on the front and only just acceptable rears and I think that was also another reason for the problem. Different wheel speeds? I had the rears changed and I stopped having the fault appear quite as often. Still did it though.
Old Oct 18, 2011 | 09:21 AM
heavychevy's Avatar
No I haven't, but I haven't gotten a code for that. The codes I have gotten (And I forget the code numbers because the shop that the car is at wrote them down) were:
Left front wheel sensor
ABS Pump
CAN signal implausible
So I guess my symptoms may be somewhat different, but mine has actually locked up a few times, once going 150+ into 10a at Road Atlanta. My light does not stay on either, if I cut the car off and back on, it goes away. CODES AND ALL (even tested by PIWIS). The only way we got the code was for me to go on track and try to make it happen again (CRAZY), which it did, without even engaging ABS and brought it straight in with motor still running and got those codes.
Old Mar 13, 2012 | 04:50 PM
silentbob's Avatar
Resolved
Sorry to resurrect an old thread, but I've been busy with work and haven't had time to log on, but I figure it would be good to post the resolution.
I wound up taking this to the shop, they did a bunch of diagnosis and reseated the wires/harnesses at all the connection points and lo and behold, the problem is gone. Hasn't come back in 2 months.
Looks like it was a loose connection somewhere.
Old Jul 21, 2012 | 09:49 PM
DNugget991GT3's Avatar
guys
im having this issue with my car tonight.
my wheel speed sensor is still showing as faulty.
there are no grounds in the harness.
we have continuity from the speed sensor to the control unit... and those lines are not grounded either. We checked the brown wires.. one of them we have continuity, the other brown wire seems to have a diode, and we cant get continuity through it (checked both directions).
what do you guys think is going on ?
Old Jul 21, 2012 | 10:25 PM
does anyone have a wiring diagram of the PSM/ABS control unit ?
Old Jul 22, 2012 | 09:32 AM
jpflip's Avatar
you've got pm
Old Jul 22, 2012 | 12:22 PM
Fasoole's Avatar
Fasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant future
I got same problem Took it to dealer checked my tires sensors cleaned them still same fault show up
Then they changed brake sensor its inder the steering wheels and if fixed
Usually i was getting this error as soon i use brakes
Hope thats help
Old Jul 22, 2012 | 12:24 PM
Jp, pm replied.
Old Jul 22, 2012 | 12:29 PM
Durametric won't clear the codes. The light stays on, and the error stays on.
It doesn't clear and then return, it just won't clear.
Has anyone ever had a failed abs/psm control unit ?
