Need help with part number, could not find
Old Dec 8, 2011 | 09:43 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
in pdf parts catalog. I'm missing the bolt on the turbo cover plate, the cover plate is part 14 in the link below. The bolt is on the side of the turbo plate cover, I think it attaches the plate cover to the oil containment container (part 8 in the picture).
http://www.pelicanparts.com/cgi-bin/...0COVER%20PLATE
The bolt is fairly short in length, probably was left out during servicing.
Was ordering some other parts, was hoping to add this to my order.
Thanks.
Old Dec 8, 2011 | 10:29 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
I would just take the other one off the other side and go to homedepot etc. and match it up. I assume your taking about the short 10mm bolt that holds the heat shield over the turbo and attaches to the turbos oil container.
Old Dec 8, 2011 | 11:56 PM
JSBear's Avatar
I was thinking about that ...
That may be best and likely cheaper
Old Dec 9, 2011 | 12:47 AM
gearhead's Avatar
No problem, also if you can't find a bolt short enough, just buy the long one and corresponding nut to fit, thread it on then cut the bolt however you want and then back the nut off. It will true up the threads and make it easy to install.
Old Dec 9, 2011 | 07:46 AM
jpflip's Avatar
Strange I have lost exactly the same bolt on one of my turbos...
tropicatango
Jun 8, 2025 01:00 PM
Chris Green@USP
997 Turbo Vendor Classifieds
Jan 28, 2016 02:22 PM
tropicatango
Dec 4, 2015 02:45 PM
carwash
Sep 26, 2015 03:11 PM
Chris Green@USP
996 Turbo Vendor Classifieds
Aug 20, 2015 11:30 AM
