How much BHP on straight K24 at 1.1 / 1.2 ?
Yes John you're right .. if you take a look at one of mine previous posts in this topic , i also said that FVD (sure in my knowledge) is the only one in Europe that use 5 Bar for K24/26 conversion..But RUF and Rs-tuning don't use it.
In any case if the tuned MAP works accordly with Knock sensor , does not the ECU retard timing to prevent any engine damage if A/F ratio become too lean ?
It's essentially an emergency function to save the owner from blowing up his car should he get bad gas or other problem with the vehicle that causes knock (like tweaked up boost without having a tuner adjust the fuel map/timing to match).
You might be at risk or you might not with or without a FPR, it depends on how your tune works at your boost level. FPR costs less than 100 EUR, install takes a couple of hours first time around. I believe an engine is like 15000 EUR and takes a couple of days to swap. Easy choice as I see it.
plane and simple, you need a tuner that will not damage your car, add more fuel if you want to be safer.. its a simple debate.... spend a few thousand now on a real tune, with a 5bar, you might as well send them off and make 16gs out of them, or take a chance of spending over 20k.... your car is telling you something is REALLY WRONG....... what someone else does wouldn't matter to me if i knew my car would not run within the limits it should... the choice is yours... good luck
I run 1.1-1.2 but on stock K24's NOT on 16g's.
That's an honest assesment. People can get so carried away (and fooled) with dyno numbers.
I ran 530 AWHP on Giac's Dyno. Stock 996T runs 330 AWHP. What's my crank?
Most say that you add 15 to 20 percent to the wheel dyno to come up with crank??...But then which,,a rear wheel dyno or an AWD dyno to say that....lol...
Look at my Sig. My car started life as an X50, it's now Garrett Ball bearings, EVO intercoolers, 60lb injectors, Hitachi MAF.
Wow...On an AWD dyno to have 530 HP with k24s,on pump gas??..IMO it sounds like a happy AWD dyno because thats in K24/18g range.
In my previous experiences Mustangs used to read 10% higher then Dynojets. IE stock 996tt reads 325 on EPL Mustand and 365 on my local Dynojet. Over the summer Dynojet has released an update and Dynojet close to me reads just like a mustang. Its rather annoying because you just dont know what to expect...
#TeamAIM
#TeamAIM
Sorry,did not look and see the GT 28's
On an AWD dyno,k24s pump gas?? That would be impressive!
