964RS LWFW conversion parts list FYI...
I have not seen a post listing parts needed for a 964RS/GT3RS/RSR flywheel conversion, so I thought I would share. Hope this helps.
RS LWFW parts list
Clutch guide tube: 950 116 813 30
Guide tube screws: 900 270 055 02 (2 ea)
Starter ring gear: 964 114 143 31
Throw out bearing: 944 116 080 01
Flywheel bolts: 928 102 151 01 (9 ea)
Flywheel: 964 102 239 31
Pilot Bearing: 931 102 111 00
Pressure plate bolts: 999 510 015 02
Note:
The following is added for the addition of the lightweight RS pulley. Porsche released a TSB on the 997 GT3 related to fix an issue with this stock weight pulley coming off when the lightweight flywheel is installed. So far I have not personally heard of this happening on the 996TT, but I personally would at least re torque and loctite the pulley bolts for good measure.
996 102 017 95 Crank pulley
999 025 174 02 Washer
996 102 550 80 Bolt
RS LWFW parts list
Note:
996 102 550 80 Bolt
They say you're supposed to replace the pulley bolt every time you remove it but it's not a TTY type fastener. 126ftlbs on the spec if I recall, little medium threadlocker doesn't hurt as suggested.
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
SharkyShark20
Sep 19, 2015 09:54 PM
