N75 Valve Replacement - Split in Hoses
Old Dec 25, 2011 | 05:32 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Just about to fit my new N75 valve and noticed the hose going from the valve to the y-pipe has a split in it
I've heard the N75 valve can be awkward to reconnect, so I was wondering, should I replace the hose with a new OEM one, or would a longer length of hose help?
Old Dec 25, 2011 | 06:03 PM
ttboost's Avatar
I put a longer one in when I did mine.
Old Dec 25, 2011 | 06:09 PM
ant_8u's Avatar
Did you keep the original hose?
Did you retain the 90* elbow?
What kind of hose did you use?
I noticed the only part of the N75 hosing that had a hose clip in place was the end which attaches to the y-pipe. Do the other hoses need a hose clip or not?
Old Dec 25, 2011 | 06:13 PM
ttboost's Avatar
I used a 6 inch piece of regular vacuum hose, put a "pigtail" in it, so I have a little room to remove the valve and disconnect the hose easier. I put zipties on EVERY hose I could see. If that hose pops off, you're in big trouble.
Old Dec 25, 2011 | 06:16 PM
ant_8u's Avatar
Nice, thanks
Old Dec 25, 2011 | 07:56 PM
and that hose can be dangerous if not changed... so good find...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 2, 2012 | 01:06 PM
ant_8u's Avatar
Done - All is good
Old Jan 2, 2012 | 01:22 PM
Yazz911TT's Avatar
Yazz911TT is infamous around these parts
I wish my fix was this easy
Old Jan 2, 2012 | 01:26 PM
ant_8u's Avatar
Yazz - If it makes you feel better, I'm still drilling into my cylinder head because my exhaust manifold bolts sheared off into it
Old Jan 2, 2012 | 01:37 PM
Yazz911TT's Avatar
Hope u get that sorted mate!! I cant sit still for one minute, im constantly sitting then standing, researching on here and the internet, looking for a way to get this damn pipe off and the snapped bit out the tank hole. My mechanic will come down one day in the week and sort it in 10mins but i just want it done!! Its the only thing that needs doing then i can get mapped from TODd!!! AAAAAAAAAAAARRRRRRRRRRRGGGHHHH!!
Old Jan 2, 2012 | 01:46 PM
ant_8u's Avatar
Just seen the pictures you posted
Ouch
Old Jan 2, 2012 | 01:58 PM
Yazz911TT's Avatar
Ouch
YUP.....OOOOOOOOOOOUCH is RIGHT!!
Jun 10, 2017 07:45 PM
The Oss
Aug 24, 2015 08:19 PM
TrackOne
Aug 20, 2015 12:56 PM
ECS Tuning - VW
Aug 19, 2015 10:43 AM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
