Boost controller 996 Turbo
Old Dec 27, 2011 | 06:03 AM
laurent965's Avatar
laurent965 is infamous around these parts
Hi guys , i need some advised.
i would to buy this product :
Greddy Profec B Spec II Boost Controller
Right now i'm running 1,4 bar everyday, but for track days, i would like to lower the boost to 1,0 bar. Is it the product I need ? Do I need to reprogram the ECU ? is it plug and play ?
Happy New Year to 6speed , from France
Old Dec 27, 2011 | 07:37 PM
Tim941NYC's Avatar
You can use it but your wastegates would need to be set to open at 1bar "on the gate" with out any boost controller hooked up(no hoses to them). Then use the ebc to make the 1.4 your car is tuned for. In other words just wastegate would be 1bar. boost controller on would be 1.4 bar and you would not use the N75 valve anymore, you would remove it from controlling the boost but leave it wired in so that the CEL would not come on. There is more but lets start here. You can use the boost controller to do more but above is easy.. For now. lol
Old Dec 27, 2011 | 11:59 PM
laurent965's Avatar
Ok thanks for the info, it looks like not an easy installation :-(
Old Dec 28, 2011 | 04:55 AM
waymegelli's Avatar
waymegelli is a jewel in the roughwaymegelli is a jewel in the roughwaymegelli is a jewel in the roughwaymegelli is a jewel in the rough
It's definately not plug and play and is best left to someone that knows what they're doing. Very easy to get something wrong and screw up your car. And I'm speaking from experience.
Old Dec 28, 2011 | 04:59 AM
laurent965's Avatar
Maybe I should try to control the boost with my right foot
Very inexpensive set up
Old Dec 28, 2011 | 07:40 AM
Tim941NYC's Avatar
LOL. I don't think its a big deal but it is work.. Why not get a program that you can switch between? One will be 1bar and the other 1.4bar? By the way are you on stock K24's?
Old Dec 28, 2011 | 11:07 AM
laurent965's Avatar
No my k24 are modified in the uk, but not sure what they are, they are called k24/ mrc 700 cause they are good until 700 to 750 hp
Old Dec 28, 2011 | 11:16 AM
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
I would recommend the HKS EVC. I've had three Greddy units fail on me. They blow more than Jenna Jameson.
Old Dec 28, 2011 | 11:54 AM
you cant use a ebc without a retune for it....
and when you turn it off you will run the minimum wg pressure...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 28, 2011 | 12:07 PM
Tim941NYC's Avatar
you would only need a re tune if the boost controller was used to raise the boost above what is is tuned for originally. Not so in this case. OP wishes to use the boost controller to LOWER the boost to 1bar from his tuned 1.4bar. The ECU will NOT see tables/maps that it does not already see at 1.4 bar.
Old Dec 28, 2011 | 12:08 PM
Tim941NYC's Avatar
I also use the hks evc and love it.
Old Dec 29, 2011 | 11:38 AM
laurent965's Avatar
Thank guys for the info
Old Mar 19, 2014 | 11:00 PM
b00m's Avatar
b00m is infamous around these parts
Question K24/18g upgrade - do I need the Greddy EBC?
I have an '04 996TT Tip and I'm about to upgrade the turbos to K24/18g along with 60lb injectors, a GT2 fuel pump, and the SpeedTech 2.5" quiet exhaust. I upgraded the DVs, plugs and F-pipe previously and got a Softronic tune which I'm about to update for the new configuration.
Since I have a Tip, why shouldn't I set a maximum boost via the wg (or elsewhere?) and not even mess with the Greddy EBC?
I'll admit, when I first put this mod idea together, I didn't appreciate the vulnerability of the Tip to shall we say, "excess torque." I planned on conservative driving while my bride could see me, and then planned to turn the Greddy to "11" when I wanted to kick butt. Now I think 1.4bar occasionally is about all I can get away with.
Should I be upgrading the torque converter now too?
Appreciate any thoughts on all this.
Old Mar 20, 2014 | 12:15 AM
Be careful with 1.4 bar on a TIP.. I would run 1.2bar...
9.66
click to view
Old Mar 20, 2014 | 02:35 AM
Fasoole's Avatar
Fasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant futureFasoole has a brilliant future
Please don't mention this name she was my Angel 10 yrs ago
BlackMarketRacing
Dec 8, 2015 01:49 PM
PelicanParts.com
996 Vendor Classifieds
Aug 20, 2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:43 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
