New custom 3" Exhaust Build by T3. Dynos Added. 60+ whp
Dropped my car off off at T3 Industries for custom exhaust. Shop is new but the owner does high quality fabrication work. He was part of the crew working on the ASP/DC Kalis Camaro that belongs to his brother and member here phillym5.
He wanted to build a performance system for the 996tt saying there were gains from going 3.25" -> 3" with straight through mufflers rather then the 2.75 that I had before. The outlet on A30s is larger then 3" and thats how big the beginning of the exhaust is to perfectly match the outlet of the Alphas. There will be more pics of the finished product as well as sound clips soon....
#TeamAIM
#TeamAIM
yes there will be fresh dynos. car will be going to Tony@EPL soon for some testing and tune adjustments if needed. i am also changing interoolers, will get a thread up on that soon...
#TeamAIM
#TeamAIM
I can hear it already... It looks like markski's setup. Looks good, dynomax cans? In my minds eye I can not see the X used in that form (cross flow) making more power then not using it, I know the sound is worth it though.
Ironically KPG went from straight pipes to the X( evoms made it) and he made considerably more TQ and HP... common sense would tell you otherwise...
I actually have no answer for it... It does sound a lot better though unlike the common tracker type of sound you get from conventional after market systems...
2001 996TT 3.6L and stock ECU
On the high HP cars we never went back and forth to test... it did make 1100whp on Robmds... then on our 997 TT it made 870whp... etc...
Which dyno did he make 1100?
[QUOTE=c32AMG-DTM;3416186]Just FWIW, KPG's custom EVOMS exhaust isn't really an X-design, IMHO. Each side is pretty isolated except for a small "balancing" pipe:
I dont recall exactly but Im pretty sure it was... he changed it... I may be wrong...
at todds... our 997 did as well...
That dyno results was in 2007 or 2008 at Todd K, which was only 27 pounds of boost if I recall correctly? I have been above 35 pounds since then and I still have Marski exhaust on it. I do not know if I could make more power on straight pipes; however, to me it is not worth it. I love the sound that his cross flow makes and I will stick to it until it falls apart.
Robert
Robert
yeah i saw nearly finished product last night and it looked awesome
same man - cant wait to hear it...
#TeamAIM
#TeamAIM
Here are few cell phone pics of the wider opening reducing to 3" as well as flanges etc...
#TeamAIM
#TeamAIM
