Ride Heights - 996T versus 996 GT2
Old Jan 9, 2012 | 02:02 PM
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
Folks, I am just wondering and i know somebody has the answer on this one.
What is the standard (from factory when car is delivered) ride height of :
1/ 996 Turbo
2/ 996 GT3
3/ 996 GT2
and what are you running now.
1/ just on OEM suspension
2/ on coil overs (and which ones)
Just curious as I am in the process of getting to dial in my JIC Cross coil-overs as I found my setting too low and too hard. So I raised it about 1/2 inch and went for a very soft ride (on 19 inch rims)... boy... what a difference. I assume that almost everybody out there is wondering what the best compromise is.
I am listening .
Old Jan 9, 2012 | 02:10 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Where and how are you measuring ride height?
I'm on 18's with 235/40s and 315/30s
Stock Euro suspension
Measuring from the ground to the highest point of each wheel arch is 26"
Old Jan 9, 2012 | 02:22 PM
Dr. Jekyll's Avatar
Dr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of lightDr. Jekyll is a glorious beacon of light
I'm 25" fender to ground with my JIC c/o's and 18" rims (225 and 295's). The nice thing with the JIC's is that the shock body is adjustable so you can change the ride height without messing with the spring preload. I have them on the softest setting in the front and 2nd from the softest in the rear and the ride isn't bad. They were on the car when I bought it so I'm not sure what the spring rate is.
Old Jan 9, 2012 | 05:26 PM
DNugget991GT3's Avatar
i have the same suspension as you
i am also on 19" wheels
my car is lower than a gt2. my ride isnt THAT bad.. did you dial in the shocks ? they may be on too stiff.
p.s. i live in NYC and i drive the car through the city all the time..
Old Jan 9, 2012 | 06:03 PM
hroussard's Avatar
Thanks Steve. So looking at your avatar, your car is quite low. What are your front / rear shocks set to? And as you say that yours is lower than a GT2... do you have the exact measurement . I believe it is measured at a certain point under the middle of the engine ( for the rear). Appreciate it!!
pshep138
Sep 1, 2015 09:45 AM
tkeck3
Aug 25, 2015 02:52 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
Aug 19, 2015 06:35 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
