JRZ Coilovers - Broken Spring
Old Jan 9, 2012 | 02:02 PM
bob'5's Avatar
bob'5 has a spectacular aura aboutbob'5 has a spectacular aura about
Just found out that one of the rear springs on the coilovers has snapped.
How hard are the replacement springs to come by? Never had a broken spring before and thought JRZ's were meant to be of good quality?
Looks like the car will be laid up for a while
Old Jan 9, 2012 | 02:51 PM
Tim941NYC's Avatar
Should not be hard to get a replacement. Change both rear springs thought and I would even change the fronts too. All you need is the coil ID, height, lbs (650llbs) and rate (straight or progressive). I am unsure of the sizes on jrz but someone will know.
Old Jan 10, 2012 | 03:58 PM
8wrench's Avatar
8wrench is infamous around these parts
Agree with replacing remaining springs at the same time
Old Jan 10, 2012 | 04:29 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
I got my replacement springs from Swift. They sell by length/diameter/stiffness, as Tim said. Replacing the rears is pretty easy. Fronts, not so much. Make a note of where the adjusters were set on the old ones to get the ride height approximately the same.
Jon
Old Jan 10, 2012 | 04:54 PM
TTTerror's Avatar
TTTerror is a jewel in the roughTTTerror is a jewel in the roughTTTerror is a jewel in the rough
Big Bucks for Broken Spring
How many miles on springs? That`s the key driver for replacing all or just one. Try contacting JRZ...worst they can say is "no"
Old Jan 11, 2012 | 11:30 AM
Bryan @ JRZ's Avatar
Bryan @ JRZ is infamous around these parts
We do not manufacture springs and to my knowledge, haven't done so in the past. Regardless, a failure of a part on our product is still of concern.
Could you send me an email with pictures of the failed spring?
bryan@jrzsuspension.com
Old Jan 11, 2012 | 03:50 PM
TTTerror's Avatar
Bryan...if you'd read the orginal post, you'd see he's talking about the spring integrated as part of the coilover. I'd PM Bob5 and resolve if possible...good PR for JRZ.
Old Jan 11, 2012 | 03:55 PM
Correct, the spring is integrated in a coilover damper system. However, that is not a part that we make. The spring is generally sourced 3rd party by ourselves or our dealers and installed on the damper system.
Edit: I cannot spend PMs, apparently I do not have enough posts. Would someone mind sending him one on my behalf with the email address I posted?
Old Jan 11, 2012 | 05:46 PM
TTTerror's Avatar
Good info for all...PM sent to Bob'5...cheers
Old Jan 13, 2012 | 07:42 AM
bob'5's Avatar
Thanks all, have contacted the European JRZ rep Erik who said the springs are made by Eibach and should be easy enough to source. Will be taking a look at the spring today for part numbers so will take pics.
Old Jan 13, 2012 | 09:11 AM
bob'5's Avatar
Pics taken.
No part numbers found, coilovers still on car but used a mirror to check the back of springs.
The only part number is on the black plastic collar near the helper spring: ZT - 1 - X002A01
Feelgood MD
Mar 24, 2016 09:35 AM
ModBargains
BMW Vendor Classifieds
Oct 13, 2015 03:46 PM
ModBargains
Audi Vendor Classifieds
Oct 13, 2015 03:45 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
