Installing Recaro Pole Position
Old Jan 19, 2012 | 07:19 AM
Cody D's Avatar
Cody D is infamous around these parts
I've searched a lot over the past couple of weeks, maybe my search skills are lacking but I can't find any definitive answers on the proper mounting of Recaro Pole Position seats in a 996 Turbo. I don't know which bases and rails to use, the Sparco universal ones or the Brey Krause ones. I don't know where to mount the seat belt receiver, on the seat mount or to the floor, if it's to the floor then where and how?
I'd like to hear from people who have actually done this, can anyone shed some light on this for me?
Thanks.
Old Jan 19, 2012 | 08:10 AM
raineycd's Avatar
Universal mounts will work but you will need the 996 converter rail so they will mount in the existing mount points. It is a long thin, flat piece of metal with a bend near the front. 2 per seat.
I mounted my seat belt rec to the seat bases (metal uprights), but if you are using them in any DE or racing, you will want to check with them to be sure that is ok, etc.
Old Jan 19, 2012 | 09:01 AM
Snowczar's Avatar
Snowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to behold
Did you check with Recaro? I have their Sport seats and they also supplied the install kit. 996 kits are one of the few they actually make themselves.
John in Vancouver
Old Jan 19, 2012 | 02:38 PM
Cody D's Avatar
Awesome thanks, I'm not doing any racing with the car so I think I'll probably use the uprights.
John in Vancouver
The company that I'm buying the seats through had called Recaro about it and was told that the universal Recaro mounts are not a very good solution. I may phone Recaro directly and ask about solutions.
Old Jan 19, 2012 | 03:11 PM
Snowczar's Avatar
My Recaro dealer found a specific bracket set for the 996 listed and got it from Recaro USA.
John in Vancouver
Old Jan 19, 2012 | 04:00 PM
Cody D's Avatar
John in Vancouver
Thanks, I'll phone Recaro.
Old Jan 20, 2012 | 07:05 AM
mmm635's Avatar
mmm635 is infamous around these partsmmm635 is infamous around these parts
Thanks.
I just mounted the Sparco 2000's and tried using a Brey-K side mount with the Sparco sliders and they would not line up with the bolt holes. The BK were designed to use with the factory rails that are to be removed from the car - no aftermarket base necessary. The directions are somewhat vague, and shows an electric seat in the first diagram in which the rails are being removed. Then, it shows a manual seat in the last diagram in which the hardware is to be used. The rails on an electric seat and manual are different and cannot work in this application. They will be sent back. Maybe BK has their own conversion kit that I am unaware of, but I guess OG Racing is too.
I would make sure Recaro has all the parts first becuase this is the route you want to go. I would imagine they worked it out well for the 996TT. The Sparco's in my car are the "Plus" version and a little larger. This caused a problem with the aluminum side mounts and I had to use the steel instead.
Old Jan 20, 2012 | 07:13 AM
randomquickness's Avatar
randomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to beholdrandomquickness is a splendid one to behold
I just did a seat install and ordered my brackets and sliders from wedge engineering
Old Jan 20, 2012 | 01:18 PM
benw's Avatar
benw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant futurebenw has a brilliant future
I've been using their stuff for years. quality!
Old Jan 21, 2012 | 12:15 PM
muker's Avatar
muker is a jewel in the roughmuker is a jewel in the roughmuker is a jewel in the roughmuker is a jewel in the rough
I am really interested in hearing the final outcome of your pole position install including parts used. I am about to get a set myself but have hesitated exactly for the complexity mounting them (what parts, from which company etc).
Old Jan 21, 2012 | 03:58 PM
muker's Avatar
Did you install a set of Pole positions or something else?
Old Jan 21, 2012 | 05:49 PM
Savetheclutch's Avatar
Savetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud ofSavetheclutch has much to be proud of
I know from experience most seats (recaro, sparco, corbeau) from my experience use the same mounting hardware. I have use wedge many times for different seats and they are great but I also know that recaro sells brackets for the 996
Old Jan 21, 2012 | 08:21 PM
Cody D's Avatar
I think I've decided to go with ROTtec instead of Recaro, they have everything sorted out already and Ray's been very helpful.
Enemy
Nov 10, 2015 08:01 AM
kchu221
Sep 17, 2015 01:36 PM
ECS Tuning - BMW
Aug 21, 2015 02:00 PM
ECS Tuning - BMW
Aug 21, 2015 01:47 PM
pwdrhound
Aug 20, 2015 05:54 AM
