Pilot Super Sports on 996TT?
Old Jan 29, 2012 | 08:16 AM
texeck's Avatar
texeck is a jewel in the roughtexeck is a jewel in the roughtexeck is a jewel in the rough
I am looking at the 19" Super Sports too. But I think the best combination is the 225/40 having a 26.1" diameter and 797 rotations with a 295/30 having a 26" diameter and 799 rotations is a perfect match.
I initially was going with a 235 and 305 -- but that set up seems way off for the TT.
What do you guys think of the 26" height? I would rather be closer to 25" - rub issues potential?
SEE CHART BELOW:
225/40ZR19 (93Y) XL 300 AA A 1433 lbs. 50 psi 10/32" 22 lbs. 7.5-9" 8" 9.1" 8.2" 26.1" 797
225/45ZR19 (96Y) XL 300 AA A 1565 lbs. 50 psi 10/32" 23 lbs. 7-8.5" 7.5" 8.9" 8.2" 27" 771
235/35ZR19 (91Y) XL 300 AA A 1356 lbs. 50 psi 10/32" 25 lbs. 8-9.5" 8.5" 9.5" 9" 25.5" 817
295/30ZR19 (100Y) XL 300 AA A 1764 lbs. 50 psi 10/32" 28 lbs. 10-11" 10.5" 11.9" 11.5" 26" 799
305/30ZR19 (102Y) XL 300 AA A 1874 lbs. 50 psi 10/32" 30 lbs. 10.5-11.5" 11" 12.3" 12.1" 26.3" 792
Old Feb 20, 2012 | 02:58 PM
Duff0000's Avatar
Duff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond reputeDuff0000 has a reputation beyond repute
Originally Posted by tgsmith4845
Yes, that sounds like too much rotational difference. 235/35-19 has a diameter of 25.7", 305/30-19 has a diameter of 26.5", a difference of 0.8" (3.1%). Max recommended rotational difference is 1% so you don't chew up your differential.
Where are you getting your data from?
I just pulled this off the Michelin website:
225/40/19 Diameter 26.1''
305/30/19 Diameter 26.3''
235/35/19 Diameter 25.5
I run the 225/40/19 and 305/30/19
This matchup is closer then the 235/35/19 315/25/19 (PSS does not make the 315/25 size)
Old Feb 20, 2012 | 06:45 PM
texeck's Avatar
See my note above - I am going to go with either the 295 or the 305 rear setup too (the 295 is actually closer in height and rotation). You haven't had any rubbing with the 26" height? Do the 40's up front change the driving behavior vs a 35?
Old Feb 20, 2012 | 08:03 PM
Nikolas's Avatar
Nikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant futureNikolas has a brilliant future
26" diameter will more than likely rub on a 996TT.
Old Mar 3, 2012 | 06:44 PM
texeck's Avatar
Hate to revive this post - but want to see if anyone is running these (19's) with a 26" diameter on a 996TT. I need some tires - and Michelin Pilot Sport discontinued in 315/25/19???
Old Nov 15, 2012 | 07:34 PM
trident111's Avatar
trident111 is infamous around these parts
Is anyone else running 225/40/19 in the front (26.1" diameter)? If so are you experiencing any rubbing or is it a good ride?
Thanks!
Old Nov 15, 2012 | 09:32 PM
Aerodude's Avatar
Aerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant future
From what I've read, 26" should be OK if you're running stock height. I think it could be a problem if the car is lowered. Can anyone confirm either way?
Old Nov 16, 2012 | 07:10 AM
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
Thanks!
I just put that size on my car in PSS's. I have only taken it through the neighborhood giving it some tight turns and couldn't hear or feel any rubbing. I am also lowered 1" on H&R's.
Old Nov 16, 2012 | 09:18 AM
Aerodude's Avatar
Since a little more time has passed since I last asked -- anyone find the best combination of MPSS tire sizes for 18" wheels?
Old Nov 16, 2012 | 09:28 AM
sinKing's Avatar
They don't have an 18 wider than 285. This is exactly why I begrudgingly stepped up to 19's. There is no good combination of PSS's for 18's. At least not for this car.
Old Nov 16, 2012 | 01:33 PM
Giorgos Cayman's Avatar
Giorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond repute
What do you thing about 245/35/19front and 305/30/19 rear???
Old Jun 1, 2013 | 02:02 PM
Feelgood MD's Avatar
Feelgood MD is infamous around these parts
that'd be too far off (13 revs/mile or 1.3%). closer match to 245/35/19 is 295/30/19.
alternatively, you could do 225/40/19 fronts and run either 295/30/19 or 305/30/19. i have no real life experience with this, however, just going off an online calculator. http://www.tacomaworld.com/forum/tirecalc.php
i wonder tho, would any of those rub on a stock suspension? 305/30/19 is 1.2" taller than stock 295/30/18 so i'd be concerned that may rub but some guys seem to get lucky and don't rub
Old Jun 1, 2013 | 08:22 PM
Aerodude's Avatar
I ended up trying out the following size for MPSS tires:
285/35-18 on OEM 11" wheels on rear (25.9" dia; 804 rev/mile)
235/40-18 on OEM 8" wheels on front (25.4" dia; 819 rev/mile)
With a few thousand miles on the street and one HPDE event, I'm happy with these tires and sizes so far. I was worried about the slightly narrower rears (10mm less than OEM), but I'm not noticing any less grip on the rear and maybe even better handling (less understeer) together with the 235s in the front. I can also confirm that there are no rubbing issues with the 25.9" diameter tires with stock ride height.
COBB Tuning
Nov 9, 2015 08:02 PM
Nikg
Sep 21, 2015 10:32 PM
pshep138
Sep 1, 2015 09:45 AM
WheelB
American Muscle
Aug 25, 2015 12:36 PM
Sterlingc1975
Aug 22, 2015 02:30 PM
