Brake pads on a 996TT wont release.
Old Jan 28, 2012 | 04:55 PM
Edward Bloomer's Avatar
Edward Bloomer is infamous around these parts
Question Brake pads on a 996TT wont release.
Tyring to change my brake pads. Did everything I'm supose to do. Release cotter pin, remove sensors, release center pin, compressed he caliper but the pads won't come out. There seems to be something from the piston thats stuck on the pads. There is two shaft about the size of dime thats coming out of the center of the piston thats stuck on the pads on both side. What am I missing here.
Thanks.:co nfused:
Old Jan 28, 2012 | 05:48 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
Thanks.:co nfused:
THere are vibration dampers that are stuck on (adhesive) the back of the pads and fit in the piston.Use a spatuala or something thin in between the pad and the vibration damper to seperate the two and they will come out
Old Jan 28, 2012 | 05:59 PM
Yep found out the hard way. Messed up one. I put a putty knife on the wrong side and broke off the screw holding the pad to the pucks. Do I really need those things? If yes I have to go to the dealers to get a new set. I don't seem to have those in the front brakes.
Old Jan 28, 2012 | 09:00 PM
joetwint's Avatar
yes ,you need them otherwise the brakes will squeal like pigs.U should have them in the front too.I would get them from the dealer....they are not very expensive.Good Luck!
Old Jan 28, 2012 | 11:52 PM
pwdrhound's Avatar
I took them out when I changed my rotors and pads and my brakes are quiet as a mouse. Not a single squeal..... even with track pads. Its funny how everyone has a different experience when it comes to brake noise. I always slightly bevel the front and rear of the pads when new and that seems to take care of any noise. Do not install those things if you plan to track the car as the adhesive will not withstand the heat anyway.....
Feelgood MD
Mar 24, 2016 09:35 AM
ModBargains
997 Turbo Vendor Classifieds
Oct 13, 2015 03:55 PM
XLR82XS
Oct 5, 2015 07:02 AM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
