Best sequence for performance mods
Old Feb 1, 2012 | 10:03 AM
thomapa1's Avatar
thomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of light
My thoughts = (in terms of daily feel/liveability/cost)
1. Short Shifter
2. Suspension
3. Decide your plan for total power/output...this will determine your next steps including any combination of the following:
3a. Turbos
3b. Flash
3c. Exhaust
3d. Clutch / Flywheel
3e. Brakes
Driver education supersedes all of the above
Old Feb 1, 2012 | 12:46 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
If you're doing DEs, would add intercoolers (preferably ones that have data showing they actually reduce IAT over stock) to the flash/exhaust combo and other suggested mods. There have been instances where flashed cars become slower than stock after a few laps due to high IATs and subsequent ignition timing reduction. Flashes are great for temporary power increases on the street, but I would highly recommend a more well rounded, systems approach type package for road course work. On the same token, the exhaust will free up power and also reduce EGTs.
Clutch is a toss up depending on its current condition.
Old Feb 1, 2012 | 01:55 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Originally Posted by mamir
Thanks for the information guys as TEXECH stated the exact questions I have for my list of performance items.
Can you please clarify that a clutch upgrade is needed with a ECU flash and mild exhaust upgrade - street application only?
TEXECH - where are you getting the ECU flash and why did you choose them? I am looking myself. Thanks.
With just a flash and an exhaust your stock clutch will be fine. When it eventually does give up, seriously consider sticking with the stock dual mass fly wheel with a friction disk and pressure plate with a bit more grip. Single mass flywheels do let the engine rev faster but the trade off is clutch chatter, less of a smooth engagement from a stop and you'll need a reflash to take full advantage of it.
Old Feb 1, 2012 | 04:01 PM
texeck's Avatar
texeck is a jewel in the roughtexeck is a jewel in the roughtexeck is a jewel in the rough
To everyone that has posted thoughts so far: Thanks so much. Its truly great to gain all this insight.
On the DE's - agree that for the track - suspension, brakes over anything else - with the exception of a good teacher/program of HOW to drive (been there - done that - but always happy to learn more from those I can learn from).
On the HP modifications - seems like everyone is in pretty good synch on what to do. There are any options - and no single defined best approach to tackle necessarily, but some things go hand in hand. And I appreciate the ideas/thoughts I didn't have - intercoolers for example.
The coolest part of all this? The potential in these cars is unbelievable!
Steve
Old Feb 1, 2012 | 04:03 PM
ard's Avatar
ard
I did exhaust/flash/wastegate first
Then suspension.
I prolly should have reversed the order. On track, you will NOT be thinking "I need more power".
A
Old Feb 1, 2012 | 04:07 PM
texeck's Avatar
Originally Posted by Duane996tt
An exhaust and flash in combination have the most fun factor as feel them in everyday driving. Instant gradification at the push of a pedal. If you plan to modify for power beyond this, then give serious thoughts to your end goal. Changing turbo's opens a whole can of worm or opportunities depending on your view of thing (and your budget). Intercoolers, fuel rails, injectors, FPR, and fuel rails need to be considered depending on which turbo's you pick. The flash you did for just the exhaust will be not be able to optimize these other mods. So you'll have to pay for another flash (or upgrade of the one you have) if you don't do all the mods at the same time. With higher power output goals, you'll also need to consider a stronger clutch assembly.
The thing you didn't mention is suspension which is unfortunately usually overlooked. The stock 996tt suspension in US form is not tuned to match the stock power. What saves most people from disaster is the AWD and substantial understeer PCNA has dailed into the car. By way of example the GT2 (also known as the widow maker) with the same engine (X50 version) has a substantially different suspension including relocation of the suspension pick up points and 2wd.
I would invest some money in suspension modifications depending on your intended use. For a street only car you don't need to get too radical. The factory X73 suspension is the safest bet as it has been through all the factory testing and you know it will work as designed. PSS10 are very nice for the street due to the adjustability and if you don't drop the car too far you won't need additional suspension components. A thicker rear sway bar is alway a help with an alignment to reduce understeer. If you intend to track the car more than occationally you can get into some seriously expensive mods.
The stock brakes are fine for everyday use but if you plan to do much track time these will at least need harder pads and better brake fluid. PCCB are fine of the street but not suited for track use.
The drive train and shifter have too much slack in them which is easily corrected using stock parts. (replace with a 997 short shifter, 964RS motor mounts and a 997 tranny mount). These are easy DIY's. Less than a days work and you don't reduce the comfort level of you car like most other mods will.
Lastly the most over looked mod is DE events. It is amazing how much faster your car will go better educated and more seat time the driver has.
The point is to try to achieve balance with the car in suspension, braking, and power. Remember anything you do to increase performance will most likely decrease comfort.
Thanks for the incredibly detailed and thoughtful response. I am right with you on all points. Following the SW/Exhaust - I will go straight to the suspension. Truthfully - I will probably stop there. The turbos and all that surrounds that - probably too far for me. But a good SW flash, exhaust, PSS10 and brakes for some DE fun this summer.
Thanks again - I really appreciate it.
Old Feb 1, 2012 | 04:12 PM
texeck's Avatar
No final decision on that yet. Most very likely it will be EPL - everything I have heard/read about Tony is fantastic. But there are others that have equally good reputations and customer feedback/loyalty out there.
Old Feb 1, 2012 | 04:18 PM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
A flashed ECU + stock exhaust = big problems at the track on a warm day. You need to open it up or rising temps can conspire to do bad stuff despite assertions to the contrary. How do I know? I didn't do the exhaust component and am still waiting for my motor to be rebuilt after being taken out by an imploding turbo last summer. Do it right. Best,
Old Feb 1, 2012 | 06:53 PM
mamir's Avatar
mamir is infamous around these parts
Thanks for the information.
Old Feb 1, 2012 | 08:49 PM
brettd007's Avatar
brettd007 is a splendid one to beholdbrettd007 is a splendid one to beholdbrettd007 is a splendid one to beholdbrettd007 is a splendid one to beholdbrettd007 is a splendid one to beholdbrettd007 is a splendid one to beholdbrettd007 is a splendid one to behold
What about upgrading the induction/air intake?
Old Feb 1, 2012 | 09:02 PM
Zmydust's Avatar
Zmydust is a name known to allZmydust is a name known to allZmydust is a name known to allZmydust is a name known to allZmydust is a name known to allZmydust is a name known to all
Clutch before upgraded turbos.
Old Feb 1, 2012 | 10:22 PM
Aerodude's Avatar
Aerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant future
Wow -- what ECU flash do you have? How was it determined that the imploding turbo was due to the lack of an exhaust upgrade (as oppose to some other problem)? Thanks for any additional info.
Old Feb 1, 2012 | 11:30 PM
tgsmith4845's Avatar
tgsmith4845 is a jewel in the roughtgsmith4845 is a jewel in the roughtgsmith4845 is a jewel in the roughtgsmith4845 is a jewel in the rough
Don't forget about the safety stuff: roll bar/cage, seats, harnesses. Last year was my first year tracking DEs and by the 3rd or 4th event I was sliding all over the inside of the car with stock sport seats and 3 pt belt. I recently added Recaro GT3 Euro seats, harness bar and 6 pt Schroth GT3 harnesses. It is amazing how light the steering wheel feels when you're not using it to brace yourself in a corner.
Have fun!
Tim
Old Feb 2, 2012 | 10:22 AM
Steamboat's Avatar
In all fairness we can't definitively conclude what the root cause of the failure was. The turbo shaft/bearings definitely failed and it's possible, although I think unlikely, that it was purely a mechanical malfunction such as the retaining nut on the end of the shaft coming loose and causing the ensuing havoc. As you can see from the original thread, a great deal of the conjecture centers around the temperatures that day combined with the stresses a track environment produces and how mitigating the heat might have prevented the incident. At a minimum that would have included a freer flowing exhaust system. I was running a Stage I 550 flash from Evoms and feel confident enough that the tune itself was not the issue that I have elected to stay with them for the rebuild. There's actually quite a bit of good information contained in this thread for those who are contemplating such performance mods. Hope it helps!
https://www.6speedonline.com/forums/...ts-racing.html
Old Feb 2, 2012 | 12:49 PM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
If you ask 20 people, you'll get 21 opinions. My advice is... it will save you some money if you do everything at once assuming you have the money. If you are on a budget, just do the flash first since it is the biggest bang for the buck. I know many people are running a flash w/o exhaust with no problem. Next one should be the exhaust. For everything else, put them in a box and draw them out one by one... and mod them in that order.
