Troubleshooting Misfire
Old Feb 7, 2012 | 09:16 PM
alittleboost's Avatar
alittleboost is infamous around these parts
So I've Searched and read most of the following threads about this problem, but in my case my misfire only comes at idle.
Scenario: The car is a EVOMS GT700 kit, when cold starting the car the RPM dips and then catches to normal idle, as the car gets warmer it idles normally but I can hear the misfire. I get the codes P0300 and P0304.
The Plugs in the car are the platinum NGK's installed by BBI less than 6 months ago with fewer than 6000 miles and I have changed the Coil packs on all 6 cylinders. While the car was at BBI they gave it a compression and leak down test with call passed as a healthy motor.
I am assuming I have a vacuum leak somewhere, I have a Durametric and the car does not misfire during driving conditions. I get a check engine light every 2-3 start ups after I clear the code.
Any suggestion on this would be greatly appreciated, I wouldn't normally post if I wasn't so stump! 6-Speed as a great amount of topics in the search function.
Thanks.
whtrabt
Oct 5, 2015 05:23 PM
