Headlight washer cover missing, where to buy m
Old Feb 27, 2012 | 12:34 PM
Zmydust's Avatar
Zmydust is a name known to allZmydust is a name known to allZmydust is a name known to allZmydust is a name known to allZmydust is a name known to allZmydust is a name known to all
Pulled up at the house yesterday to find that the passenger washer cover (chrome circle) was missing.
Jonathan
Old Feb 27, 2012 | 12:52 PM
jpflip's Avatar
Part# is 99662814300 (LH) or 99662814400 (RH) and it seems to be about $56.00??? Pelican got it...The parts cat. does not show the cap only. I guess you have to get the assy....
Old Feb 27, 2012 | 01:01 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
This is correct ..
I bought the whole assembly, then removed just the cap from the new assembly and installed. Kept the rest of the part just in case I need it down the road.
Old Feb 27, 2012 | 01:29 PM
m3ntal's Avatar
Senior Member
m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !
suncoast has it for like 36 bucks i'm pretty sure.
Old Apr 15, 2012 | 02:10 PM
'02996ttx50's Avatar
i just lost mine somewhere between 0 and 100.
mind if i ask. when you got the cap, what did you use to glue it back on? if it's just glue, it may be my first DIY
Old Apr 15, 2012 | 02:19 PM
JSBear's Avatar
No glue needed. It just snaps in. When you get the
new part you will see. I just removed the cap from the new assembly and installed. I think I had my wife turn on activate the headlight sprayer, then just grabbed it when it popped out, and snap on the new cap and let it go.
Old Apr 15, 2012 | 02:42 PM
it's not often i lament my divorce but i've just ordered the cap assembly @ suncoast and when i find some help to work the stalk then i'm gonna give it a shot. thanks man..
Old Apr 16, 2012 | 11:39 AM
Simi_996's Avatar
Simi_996 is infamous around these partsSimi_996 is infamous around these parts
My cap was already missing, so I just pulled the sprayer out by hand and did it myself. Some say you shouldn't pull it out manually, but I didn't care. I never use the sprayer so it doesn't have to work...just needs to look like it works.
Old Apr 16, 2012 | 02:09 PM
was easier than i thought. needle nose pliers to pull up the old nozzle. slide something under to unclip it to release. now replaced. never had to activate the stalk.
flushed with success on my first DIY.. i *may* try to tackle a running light bulb replacement
jsbear and simi..thanks for the advice..
Jul 29, 2019 11:13 AM
Michael_s
Sep 11, 2015 08:03 PM
gulf gt
Aug 27, 2015 10:27 AM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
