Ok, Opinions About My Tires
Cheers
I'm not sure good alignment (for performance) = good tire wear. My understanding is that one of the reasons the inner part wears faster is due to the relatively aggressive alignment (even stock) for our cars. In fact, I'm aware that you're often asked by a good alignment shop -- are you looking for longer tire life (e.g. even wear) or better performance?
Cheers
I recently went thru the same dilemma. My Pirellis looked brand new (still had nubs on the sidewalls), but were date coded 2003. I figure the cost of tires is about the same as my deductible and less than the diminished value hit should one blow out and cause an accident. Just a thought....................
Wow, lots of info here.
I inspected the tires. Not good.. They were made on dec of 2002.
And I found some cracking....
I am placing order for new set of Michelin pilot sports tomorrow unless yu guys have better idea...
Thanks for all the help.
Michelin Pilot Sport PS2 is an awesome tire and you won't go wrong with them. They are fairly expensive - $1536 for a set from Tire Rack. Tire Rack can give you a number of different tire options in the proper sizes. A lot of people are running the Hankook Ventus ($814/set) with good results. Car and Driver did a tire comparison a few years back and it came in second. I don't have any experience with this tire myself. Link below:
http://www.caranddriver.com/comparis...mparison-tests
Cheers
Cheers
Thanks..
I have decided on the Michelin Sport PS2 based off of endless reviews and the advice here. My local guy will get, install, guarantee no rim damage, and high speed mount and balance for 2k out the door. He can have them here tomorrow.
My next question.. can I go wider or larger on the rears? Currently it has 295 30's x 18
Then.. my local guy has a new updated alignment machine. Says he can align the car for me as well... he is not a specialist just a hard core tire shop been here for 35 years and says he does all the sports cars in neighborhood.Can he screw it up, or is it like any other hi perf sports car (BMW, Audi, Mercedes) alignment.. A guy came in with an Audi V10 and swore by this guy..
The more I drive this car I wonder why I ever had anything else. Oh, maybe the price..
315/30-18 is the next larger size of PS2 that will fit on your rim. However, I don't know if you won't then run into issues with fitting under the fender. I run this size on my GT3, but I have rolled fenders for extra clearance. I don't believe the Turbo does. Anyone else know for sure? Also you need to keep the front-to-rear rolling diameter ratio close to stock to keep the ABS/PSM computers happy (and on the Turbo the center viscous coupling). I am not sure if the 0.5" diameter increase going to the 315/30 would be a problem or not without also changing the front. Why do you want to go bigger? I would argue that you won't see a significant difference on the street unless you are running more boost than stock. If you are getting a lot of slippage now I would say it is your old tires. They get hard and lose grip with age.
There is no reason that shop couldn't do a good job if they are competent as you say. The camber and toe adjustments are not significantly different than any other performance car. I am assuming your suspension is stock and you are not wanting corner balancing (requires coilovers) or anything extreme.
Cheers
Cheers
Went with the stock 295 30 18 in the rear.,. PS2. I will update when completed tomorrow..
Again thanks for all your help guys. Oh, I will change my crappy avatar soon with better photo.
Wanted to stop in and say thanks for all that helped me with info on this tire thing..
I am all set up Michelin PS2 Feels right
Old tires were DONE>. Hard as a rock in comparison and cracked to hell and back.
All set.. thanks again..
Your 295/30-18 should be matched to a 225/40-18
You could have gone to 315/30 and 235/40.
But you should keep them matched- so no 315 with a 225
$2000 out the door? 1500 for the tires, 200 to mount and hunter road force balance...100 for tax. There is a benefit to having a local guy.... I usually don't squeeze them to tirerack prices, but keep them honest.
A
A
L.A.P.
Oct 26, 2015 11:49 AM
horsepowerfarm
Sep 10, 2015 06:09 PM
Nissan GTR
Aug 19, 2015 02:11 PM
