Radiator Leak! Need Advice Please
Old 03-11-2012, 07:00 PM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
Car just turned 20K miles and right radiator has a very slight leak and coolant smell after a drive. I removed the bumper cover with the motor warm and ran it for a while but couldn't get it to leak but the upper tank area is a bit wet like there is seepage going on.
Any luck having a shop repair the leak? Maybe a new tank to core seal? Or is replacement the only hope?
Any links on filling and purging the system?
Old 03-12-2012, 07:21 AM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
plastic end tanks so you need a new radiator. I just went through it recently good luck
Old 03-12-2012, 09:42 AM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
+1 ... atleast that is what it looks like in the photos. Common place for radiators to leak. Replacement should be the only option considered. No idea on pricing.
Old 03-12-2012, 10:04 AM
Blockhed's Avatar
check the other radiators and connections while you are in there. Radiators are around 400 dollars I believe and then you have coolant and labor so figure $600+ depending on if you do the work or shop
White991TT
10-25-2015 12:29 PM
bongnation
09-25-2015 02:58 PM
gpt817
09-21-2015 10:16 PM
markj
09-20-2015 04:19 PM
Lucid Moment
09-12-2015 01:12 PM
Quick Reply: Radiator Leak! Need Advice Please
